1990 F-150 302 Stalls When Put in Reverse - Ford Truck Enthusiasts Forums
Old 09-16-2002, 05:38 PM
Radconpro Radconpro is offline
Radconpro is starting off with a positive reputation.
Post 1990 F-150 302 Stalls When Put in Reverse
I hope someone can help me. My 1990 F-150 302 truck has been stalling lately when I put it in reverse. This occurrs when the engine is hot or cold. Dies kinda quick after putting it in reverse. This is the only time it stalls.
Old 09-16-2002, 07:19 PM
dellis dellis is offline
dellis is starting off with a positive reputation.
I'm currently going through the same problem. I have a '94 E-250, and I just had the trans replaced, "see page 1 '94 E4OD Replacement". The mechanics I've talked to, says the torque converter is locking up, but the guy who replaced the tranny says its the TPS. I'm convinced its the tranny, since it started stalling the day I picked it up from the Transmission shop.
Dave
Old 09-16-2002, 08:40 PM
What is the TPS???
Old 09-17-2002, 11:18 PM
dvldog458's Avatar
dvldog458 dvldog458 is offline
dvldog458 has a good reputation on FTE.dvldog458 has a good reputation on FTE.dvldog458 has a good reputation on FTE.
Throttle position sensor.
Its a sensor underneath your throttle body.
Old 09-23-2002, 08:05 PM
Skala444 Skala444 is offline
Skala444 is starting off with a positive reputation.
I have a 93 F-150 and it did the same thing. I work as a tech at a ford dealership, what i did was clean out the IAc, idle air control. Its just two bolts and a connector, take it off and take a cloth and carberator cleaner and clean it out, mine hasnt had a problem since. -Mike
Old 10-03-2002, 01:34 PM
dougg dougg is offline
dougg is starting off with a positive reputation.
Old 10-10-2002, 05:52 PM
cocco_78 cocco_78 is offline
cocco_78 is starting off with a positive reputation.
Damn, thats the same problem I'm having with my 94! When I shift to reverse it stalls, it always starts back up again though. Who here is still having this problem, or what did you do to fix it?
Old 10-10-2002, 11:27 PM
91f250460's Avatar
91f250460 91f250460 is offline
91f250460 is starting off with a positive reputation.
A friend of mine just put a new tranny in his truck. It turns out on his truck,(it's a diesel with the auto) that ford puts a low tranny fluid cutout in it. When the fluid gets too low it shuts down in reverse to let you know. He didn't, pulling his 35' horse trailer to a show he blew the tranny. None of the idiot lights ever came on to indicate a problem. However he is in litigation with a local quick change oil shop because he had the full service every three thousand miles. The most recently was a week before he left for his trip. What's the saying, you get what you pay for. Hope this helps, don't know if it's related to your problem but definitely food for thought.
T. Roberts
UFD Local 1147
Old 10-12-2002, 07:28 PM
Redneckerson Redneckerson is offline
Redneckerson is starting off with a positive reputation.
The 1990 Bronco I gave to my dad stalled in reverse. This all started out when the air conditioner was on and got progressively worse. I did a check of the TPS and it was way off. An adjustment to .993vdc and it was like a new truck. Good place to start. I ended up having to take the throttle body off as I had to elongate the holes to achieve the voltage I wanted. While it was off I cleaned the throttle body and IAC. So as previously posted these will most likely cure problem. Good luck and let us know what you come up with.
RSH
Old 10-12-2002, 11:26 PM
TexBand TexBand is offline
TexBand is starting off with a positive reputation.
I have a '91 F-150 with 5.0 that had the same problem. Mine started right after fixing the AC, so we suspected that. NOPE. Read this board, and replaced the AIC today. Purrs at idle now! Thanks gang.
Old 10-13-2002, 02:39 PM
I went out and ordered an air idler control valve at NAPA for $48. They had to order it and it should be in next week some time. I'll letcha know how it works
Old 10-15-2002, 09:49 PM
Ok, well the idle air control valve was not the problem. I put a new one in tonight and it still stalls
Stalls when put into Drive or Reverse GabezF250 1987 - 1996 F150 & Larger F-Series Trucks 39 10-07-2016 07:37 PM
Stalls in reverse billf250 1987 - 1996 F150 & Larger F-Series Trucks 2 05-23-2011 11:42 PM
92 F150 stalls in reverse olrusty 1987 - 1996 F150 & Larger F-Series Trucks 10 02-04-2008 06:55 PM
stalls in reverse jsphsol6 1994.5 - 1997 7.3L Power Stroke Diesel 5 11-13-2006 05:16 PM
Put in reverse Stalls Derek 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 2 01-10-2000 10:49 AM
Tags
1990, 302, 90, 96, back, bronco, dies, f150, f250, ford, put, reverse, stall, stalling, stalls, starts, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
