1995 F150 351W Build Thread
Old 01-29-2015, 02:42 AM
TexasGuy001's Avatar
TexasGuy001
TexasGuy001 is offline
Wow! Maybe its time to throw a running salvage yard motor in it.
  #137
Old 01-29-2015, 10:18 AM
strokin'_tatsch's Avatar
strokin'_tatsch
strokin'_tatsch is offline
Maybe so. I've been thinking about just dropping a 351 salvage motor in it and seeing if it'll sell at $6000... undecided though. I've got bigger projects to work on first. Lol
  #138
Old 11-12-2015, 12:49 AM
TexasGuy001
Part 2 Begins!
I finally acquired a 2nd 5.8 to build for the new white truck. Its out of a 94 F250 this time.
So, rather than start a new thread, I thought I'd just continue this one. All the information etc will be the same.
  #139
Old 11-12-2015, 01:00 AM
TexasGuy001
  #140
Old 11-16-2015, 11:22 PM
strokin'_tatsch
Remind me. What happened to the 351w I sold you?
  #141
Old 11-16-2015, 11:33 PM
TexasGuy001
I sold it when I sold the black truck. Wish I wouldn't have done that.
  #142
Old 11-17-2015, 03:40 PM
strokin'_tatsch
Dang. Why'd you get rid of the regular cab?
  #143
Old 11-17-2015, 11:58 PM
TexasGuy001
Mainly because of the leg room. It was just too uncomfortable to be in for any period of time. The new truck is a super cab.
  #144
Old 11-23-2015, 12:13 AM
TexasGuy001
I am starting a new parts list. This build will be very similar to what was initially planned, but I may not be upgrading heads or intake at first.
Before I order the Pioneer FRA205 flexplate, I just want to verify that it is what I need. I remember Conanski saying to get one for a Crown Vic with 5.8 and AOD.
  #145
Old 11-23-2015, 12:23 AM
TexasGuy001
This 94 5.8 motor has the AIR injection into the exhaust manifolds. The last 96 5.8 I was going to rebuild did not have any AIR system. The 5.0 has it in the back of the heads. I'm debating on what to do about this. The headers I have seen have the EGR but not the AIR. I am considering these two headers. Either the JBA 1628S, or the Summit Pacesetter SUM-G9036. I have a set of JBA headers similar to these on the Mustang and am very happy with them, so I am leaning that way on the truck. I'd like to only do it once, but the others seem like a good deal with not complaints on here.
http://www.summitracing.com/parts/jb...rd/model/f-150
http://www.summitracing.com/parts/su...rd/model/f-150
  #146
Old 11-23-2015, 06:53 AM
Scndsin's Avatar
Scndsin
Scndsin is online now
Some how I missed this thread first time around. Will enjoy following your current project.
Two things I used on my 94 is the Ford Racing balancer & the JBA 1268s. The HB has the same number cast into it as did the stock unit. One thing I recommend is VHT ceramic header paint time cured per instructions & bake cycled multiple times with increasing levels of heat prior to installation. After a few hundred miles of summer driving, There is NO discoloration or burn off.
Ford Racing & stock:
After 3 years in service:
Cup brushed, sand blasted, VHT ceramic paint:
  #147
Old 11-23-2015, 12:24 PM
pitpawten's Avatar
pitpawten
pitpawten is offline
Something very satisfying about blasting and painting
Looking good man, keep it up.
  #148
Old 11-24-2015, 12:25 AM
TexasGuy001
That's cool that the Ford Racing balancer has the same numbers in the casting. Do you have a part number? I looked on Summit and don't see it, just see one for 5.0. I remember it was there when I was looking parts last time.
Those headers look darn good. Apparently, they are well made.
  #149
Old 11-24-2015, 12:26 AM
TexasGuy001
Does anyone know if there is a header bolt kit that offers provisions for the upper intake bracket, coil bracket, and dipstick tube?
  #150
Old 11-24-2015, 12:59 AM
Scndsin's Avatar
Scndsin
I'll try & look in my receipts folder for a part #. All my stuff came from Summit, but they drop a lot of stuff & sometimes sell off their inventory in bulk. When I got ready for my FRPP SS shorties (for our 5.8 trucks) they had already sold their remaining ones to Tasca Ford who at the time marked them up to around $500. Hence, the JBAs.
Somewhere above you asked about a good roller set. I used an Edelbrock set that was reasonable ($60?) & non-multikeyway . (I'll look for it too)
As far as studs went, I cut down a pair of SS carriage bolts & sourced some allen heads from Fastenal. I also cut up my coil bracket & bolted it back together so it sits above the valve cover on the two tall studs & holds the EGR solenoid. The two AIR solenoids are hidden further back.
Warning, engine ****:
Quick Reply: 1995 F150 351W Build Thread
