Canton Oil Pan on my F150
What do you guys think about this oil pan on my lowered f150? I figure it's gonna hang down an inch or two lower thank the stock one, its depth is 10.75 inches. I dont want it to be too low. Im considering it because it claims to be "stroker clearanced" and im building a 347. Just looking for some opinions
Canton Racing Products 16-624 - Canton Racing Truck Wet Sump Pans - Overview - SummitRacing.com
You could get a Milodon windage tray and install kit for less than 100.00.No guessing,it'll fit in the stock pan and keep oil splash to a minimum.Or bolt the Canton to the block and lower it in to test fit it.No gasket/silicone until you're sure it fits.You could always send it back if you don't mark it up.
The sump is lower, but what about the rest? The front area can't be any lower and the picture they show surely looks lower.
About 10 yrs ago I bought a Canton windage tray for my 428 FE. I spent an entire evening cutting that things to shreds trying to make it clear my rotating assembly. Ohhhhhhhhhhhhhh, come to find out it only fits 390 cranks(WTF??). The longer 428 arm is too much to clear the screen. WTH is up with that?? Why make it only fit a 390ci or smaller FE?? Who builds anything like that in a performance world?? I sent it back(less the nice stud kit) and used a FOMOCO factory windage tray(without an issue, bolts right on).
Seems now they finally got their stuff straight and they have them fit stuff now(especially with all the stroker cranks now).
Brains man, brains.
The Moroso deep pan on my race car(428) was okay. The deep pickup they offer isn't anywhere CLOSE to reaching the bottom of the sump. WTH??? I had to cut the brace, heat the tube and twist it longer by 1" or so to get it down near the bottom. Then weld the brace back up. Who thinks this crap up??
46069dord
02-04-2008 06:45 PM
Firemudder
04-21-2007 07:58 PM
