ANOTHER transmission!!
Well,, in 2008, July to be exact, with 101,050 miles,, the original trans gave up the ghost,,, mind you, this is AFTER the flexplate/flywheel cracked and was replaced 2X under warranty by Ford,, the last time the tranny was re-installed,, the idiot mechanic did not line up the trans with the pins,, he just cranked her down,, and the tranny was on all cockeyed,, so it takes a dump,,, Ford says screw-off your over warranty,, ok so we put a reman Ford tranny in,, 3yr/100k so after 43k IT takes a crap,, 3yrs and 6mos,,, Ford says again, TS,, ,, so now,, we are having a Jasper tranny put in it has a 3yr/100k also,,, has anybody had a Jasper unit? The big pig "Wilber" has 144320 on it, and I DON'T want to put another trans in,, just needed to vent,,, I already told Ford,, I WILL NOT be buying another new Ford product,,
What exactly has happened to each trans? The Jasper units aren't terrible - they have a decent warranty in case something goes wrong. I just had the torque converter and front seal replaced on mine but that has been it. The previous owner apparently put a shift kit in according to the tech.
now you can look at the 6R140 six-speed gearbox with double overdrive gears transmission and yes "you will be buying a new ford product "
First
On
Racing
Day
always wanted to say that on here i havent had the chance till now
this post is for v-10 new trans but it works with PSD 2
https://www.ford-trucks.com/forums/1136965-did-you-hear-about-the-new-6-8l-v10.html
Stewart
I can always plead ignorance (I mean ALWAYS) ,,, I didn't look it up When it went in 08, I had to much other crap going on, and the wife needed the truck back on the road,,,
so what are BTS prices? That is another limiting factor,, I did price ATS,, about $4000 + 425 shipping + 500 install + 1750 core charge = 6675 and that was not in stone,,, I haven't put a tranny in yet,, where is BTS?
j/k about the free trans.
Stewart
make the trip....youll be happy you did....or have one delivered to your local trans shop for install....
