ZF5 and Borg Warner 1356 Questions....
So I got a FREE small block ZF5 and Borg Warner 1356 from my father in law. I literally just got done pulling everything and was curious to what all the electronics were on the transmission and t-case.
The truck is a 1988 f250 4x4 with a 351.
With both of these units function without the electronics? I want to drop them in my 1973 F100 and dont want to mess with any electronics. Wanna try n keep it simple.
The truck had 130k on it. Anything I should do to either of these while I have them out?
With that mileage, I'd be splitting the transfer. This has nothing to do with how much the fwd was used, just a function of mileage. The oil pump, internal on the transfer case, is secured with a "nubin" cast into the transfer case housing. Just google Borg Warner 1356 and you'll see several suggestions for solving this problem. I had mine finally wear the *** through on a trip to Detroit. It took the pump out, it spun and could longer pump oil, and I lost the rear bushing in the tail housing. To repair mine I just drilled thru the new steel oil pump bracket and the transfer case housing and used a quarter inch bolt and sealed with an o ring and silicone. The truck now has over 300,000 and is doing fine. The selector linkage should also be looked at while it's apart, the early ones (thru 1990) have a system subject to wear, which gives the selector a lot of slop. Easy to remedy, when you look at it. Seems to be very common around the 150,000 mile mark...........
ClatonK
10-31-2005 09:17 PM
silencedogood
04-26-2005 03:43 PM
