Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 1997 - 2003 F150
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1997 - 2003 F150 1997-2003 F150, 1997-1999 F250LD, 7700 & 2004 F150 Heritage SPONSORED BY:
  #1 (permalink)
Old 03-26-2012, 07:33 PM
alexnite alexnite is offline
Garage is empty, add now
alexnite is starting off with a positive reputation.
iPhone hookup to On-Board Diagnostics (OBD) port
Anyone have any experience with particular apps / cables connecting your iPhone to your On-Board Diagnostics (OBD) port?
I see an app called GoPoint, but it has a bad review from an F150 owner. I suspect that some apps work well with some vehicles, and not so well with others maybe.
Just curious to see what experience anyone has before I spend any $$$
  #2 (permalink)
Old 03-27-2012, 08:22 AM
KhanTyranitar's Avatar
KhanTyranitar KhanTyranitar is offline
KhanTyranitar has a good reputation on FTE.KhanTyranitar has a good reputation on FTE.KhanTyranitar has a good reputation on FTE.
The device probably works ok, but be advised that many early ford trucks were not fully OBD-II compliant, and as a result many scan tools, even higher end consumer models, cannot access the full data streams. An example is my '97 Ford Aerostar. I can read codes, and view some live data, but I cannot read O2 sensors, fuel trims, and several other systems with my Dynoscan software running on a Palm Pilot. I also own a Cornwell OTC Techforce II and it can access all the live data that the Dynoscan cannot. The bad review might be from someone that has an early OBD-II model, or has a blown lighter fuse, and that might be causing problems. If you truck is older than about 2001, the generic readers might not be able to read all the data, and if your lighter fuse is blown, you might not be able to connect at all.
Tags
2004, 60, compliant, connector, diesel, diesels, expedition, f150, ford, gopoint, iphone, obd, obdii, picture, plug, superduty
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
