Wiring schematic for a 85 EFI 302?
found this for a dual tank setup. If you have a single tank, it should be similar without the tank selector. drawing is very small and hard to read...sorry
Normal set up for these is there are 2 separate power supplies. One comes from the starter solenoid when in "start". After engine is running, it gets power through the relay and oil pressure switch. Also goes through the inertia switch which cuts off power if you're in an accident. I think this is normally located on the passenger side under the glove box on the side.
So check fuse, starter solenoid, relay and tank selector if you have dual tanks.
The 460 setup is quite a bit different as it has the electric tank switching valve.
The 302 used a non electric valve.
Here is the wiring diagram for the 302 EFI from my 86 shop manual. Equivalent to the diagram in post #2 above.
http://i608.photobucket.com/albums/t...0/duelfuel.jpg
I still have a existing problem with my fuel gauge, a buddy put in a new pump/sending unit in from Bronco Graveyard and my gauge still doesn't work correctly. So I was looking at the schematic and wiring and noticed a black wire coming back from the tank. Does the black go to a 'groung' under the dash?
Black should be the ground, there is also an orange wire which is fuel pump ground. One thing I found with a lot of aftermarket pump/sender units, on the original Ford units there are 4 pins, two are for the fuel pump and have either a red or a brown/white wire and an orange wire, the other two are fuel gauge and have either a dark blue/yellow or yellow/light blue and a black wire. The aftermarket ones, the pin the black wire goes to is a dummy, where on the original it was connected to the metal top of the sender. As a result, if you tank isn't grounded, the gauge on 80-88 models will read empty, 89-96/7 it will read full. Try grounding the tank(s) and see if the gauge works.
Well that's what I was wondering, if the black in that connector goes into the dash. I was under there and didn't see a ground.
I have 40 ohms from the negative battery terminal to the inline pump black, 40 ohms to the negative and the black in that connector AND 40 ohms between the two blacks
Someone once posted the standard locations of the grounding points.
The black ground wires from the senders and orange ground wires from the tank pumps are all spliced together in a huge blob on the drivers side frame rail near the rear tire-well. Then a single black wire goes from there up to the dash area.
What kind of problems are you still having with your gauge?
Read this about aftermarket senders:
Auto Meter
chato86f150
13
04-09-2012 06:03 PM
hoxiii
05-10-2008 12:04 AM
