Wheel bolt pattern change
I am in need of some help. I need to change the front bolt pattern to 5 on 4.75" from the standard 5 on 5.5". I already have the back done compliments on Strange axles but the front is another matter. I am running dream beams on the front and want to know if I should just drill the new pattern in the discs or is there a swap that fits on our hubs. All of this is going on a 77 2wd F100. Any help is appreciated.
That will likely require drilling the rotors. Just make sure the wheel centers will fit over the center of the hub.
There is a chance that some random GM rotor could be swapped, but I have no idea where to start looking for a compatible unit.
I've seen and heard of people using wheel adapters, but I don't place a lot of faith in those things.
J2Davis
07-21-2010 07:43 AM
Jake616
07-06-2010 01:13 PM
badtomatoes
03-24-2006 11:29 PM
PRyan1983
02-06-2003 02:16 PM
