75' front 4x4 hub EXPLODED! Help! - Ford Truck Enthusiasts Forums
Old 03-26-2012, 03:05 AM
BuiltFerdTough BuiltFerdTough is offline
BuiltFerdTough is starting off with a positive reputation.
Hi, so i get to work to day and notice that my front right warn hub is entirely gone!
The truck is a 75' f-100 300-6 4 speed 4x4 with a d44 up front, i think it probably hapened because i didn't clean out the hub after driving through a lake
Replacing the hub itself isn't really the problem, the problem is that the tip of the axle tube where the hub seals up to the axle tube is all bent out of shape. I was wondering if anyone has any good ideas for reshaping the housing so the hub will seal properly again (and hopefully not fill with water and blow up). I'm open to anything but i reeeeeaaaaly don't feel like replacing the whole axle
Thanks
Old 03-26-2012, 07:41 PM
crazy96863's Avatar
crazy96863 crazy96863 is offline
crazy96863 is gaining momentum as a positive member of FTE.
I am confused... Is it the hub or the hub seal that is jacked up? Or something different.
Old 03-26-2012, 07:47 PM
crazy96863's Avatar
I think you might be referring to the spindle... If so I suggest replacing; metal gets really brittle after bending back and forth plus getting it perfectly round will be tough. Its only like 5 more nuts extra once the hub is off. Piece of cake. I think most solid axle d44s have the same one but check. Hit up a junkyard for the new one.
Do you have drum brakes?
Old 03-26-2012, 07:48 PM
crazy96863's Avatar
This is what I am calling the spindle. Is this what you busted?
Old 03-26-2012, 07:50 PM
crazy96863's Avatar
Yes I stole my kids coloring pages to keep from making a mess which I made anyways.
Old 03-26-2012, 08:37 PM
No its like the actual tube where the big o ring in the locking hub mechanism seals against the diff, its about 3.5-4" diameter
Old 03-26-2012, 09:57 PM
crazy96863's Avatar
Ok I think that is simply your hub. Same advise-replace. Its an easy job.
Do you have drums or discs up front?
Old 03-27-2012, 02:22 AM
Drums, is that tube permanently atached to the drum? It almost looks like it, though i haven't had a chance to pull the wheel off yet, i've never had a 4x4 front end apart before either
Old 03-27-2012, 02:34 AM
crazy96863's Avatar
It might seem like it but no. You have to disassemble the hub. Once you get your spindle nuts out the drum/hub come right off. Your outer wheel bearing will come out as well. Basically set the back of your drum on the ground and whack each of your wheel studs with a 4# sledge hammer. One or two well placed blows will do it; you might buy some nuts to thread on the end before whacking to protect the threads. 1/2-13 threads I believe.
Basically put your drum on a new hub and your back in business. Your gonna want to check the hub to make sure the disc and drum hubs are the same. I dont think the drum types are as common as the discs. If they are the same this should be a cheap trip to the junk yard. If different hit me up. I will have some extra drum hubs in a couple weeks; currently switching mine to disc. One is yours for a bone and shipping.
I think the hubs are the same on both the drum and the disc brake setup. Not sure though.
Old 03-27-2012, 02:37 AM
crazy96863's Avatar
Side note... Your gonna want all new stuff at least from the spindle nuts out. I say new i mean serviceable. Hell your ****s probably all over the road somewhere anyways.
Old 03-27-2012, 02:45 AM
Yea that old hubs long gone, i got a set of mile markers here though That all sounds good but i think your probably right saying it'll be tough to find a truck w/ drums, hopefully the hubs are the same, oh well either way a pretty straight forward solution, thanks for the help i'll let you know if i don't find a hub pretty quick here
Old 03-27-2012, 02:49 AM
crazy96863's Avatar
Just make sure any parts you reuse are in good shape. Especially the part the hub bolts to. The threads are likely to be stripped considering the hub was torn off.
Old 03-27-2012, 06:57 AM
hickory1991 hickory1991 is online now
hickory1991 is gaining momentum as a positive member of FTE.
Once you figure out what you need, try the salvage yards. If no luck there, try " Ventures truck parts" in Ogden, Utah. He has quite a few parts for Dana axles. Search Dana 44 parts on E-bay, you will see his ads. Good luck.
Old 03-27-2012, 08:39 AM
USArmyTaterness's Avatar
USArmyTaterness USArmyTaterness is offline
USArmyTaterness has a brilliant futureUSArmyTaterness has a brilliant futureUSArmyTaterness has a brilliant futureUSArmyTaterness has a brilliant futureUSArmyTaterness has a brilliant futureUSArmyTaterness has a brilliant futureUSArmyTaterness has a brilliant futureUSArmyTaterness has a brilliant futureUSArmyTaterness has a brilliant futureUSArmyTaterness has a brilliant futureUSArmyTaterness has a brilliant future
makes it easier on all if you get a chance bud
Old 03-28-2012, 12:27 AM
crazy96863's Avatar
Does this resemble the part in question?
Pulling right front axle? Nader 1999 - 2003 7.3L Power Stroke Diesel 3 08-30-2015 02:39 AM
2001 4x4 front axle issues ghig1967 1999 - 2003 7.3L Power Stroke Diesel 14 03-18-2015 07:38 PM
E-150 Rear Axle Problem nct53 Clutch, Transmission, Differential, Axle & Transfer Case 1 11-07-2011 03:12 PM
'02 F250 4X4 Front Axle Loose ??? MattL09 1999 to 2016 Super Duty 15 09-15-2009 01:00 PM
2003 f250 4x4 new Warn hubs, still slipping out of 4x4 fteduran 1999 to 2016 Super Duty 17 09-01-2009 02:19 PM
Tags
assembly, exploded, f150, ford, hub
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
