E150 / F150/bronco 8.8" axle interchangability question - Ford Truck Enthusiasts Forums
1968-2013 Full Size Vans Econolines. E150, E250, E350, E450 and E550
Old 03-25-2012, 11:13 PM
dmanlyr dmanlyr is offline
dmanlyr has a great reputation on FTE.dmanlyr has a great reputation on FTE.dmanlyr has a great reputation on FTE.dmanlyr has a great reputation on FTE.dmanlyr has a great reputation on FTE.
I have a question regarding E150 and F150 / Bronco 8.8" rear axle interchangability.
First this is for my 1988 E150 Van with a 351 EFI / C6 combo. Currently according to the axle code it has a 3.08 ratio. I would like to drop down to the 3.55 or 3.73 area as this thing is a dog towing.
And that is saying something as my little C600 at 22k only has a little 330 V-8!
So if I look around, if I find a rear axle out of a F150 that is a 8.8" will it bolt up? IE spring perches and such.
I know that Ford was not to keen on the 3.73 gears, so would it just be better to spend the money and have a set of 3.73 gears put in my current axle?
Any thoughts would be appreciated.
Thank you, David
Old 03-26-2012, 02:30 AM
95e150CW 95e150CW is offline
95e150CW is gaining momentum as a positive member of FTE.
Van axles have unique width, perches, and brake setup. My interchange catalog (for salvage yards) shows 1987-91 e150 vans as your interchangeable parts/years. You would be better served swapping out the gearset.
Old 03-26-2012, 07:27 PM
Thank you, just the information I needed!
David
Old 03-26-2012, 08:05 PM
LN323 LN323 is offline
LN323 is starting off with a positive reputation.
Not to jack the thread, but..... that was my question.... could guys like us with the vans (I have a 1990 E-150 Club Wagon) just change out the internals from an F-150 8.8"?
Old 03-27-2012, 01:12 AM
As far as I know, we can swap in anything from any 31 spline ford 8.8 inch axle with a 7/8ths crosspin, except axle shafts. I fitted my 95 E150 with an Eaton electronic locker they advertise as being for F150s and Broncos. ABS gave me some trouble until i found contamination on the tone ring. Axle shafts from 87-96 e150 vans are apparently the same (per my interchange catalog.) The cost of new internals is so low, its not worth having used internals. I am contemplating a 3.73 gearset, new they only cost 130-200 bucks, and a full rebuild kit for the 8.8 is only 80 bucks or so more. I recommend reading the guides available on 8.8s before you try, as certain parts of the task (pinion preload and shimming) are not easy.
The van axles are the widest version of the ford 8.8.
Old 03-27-2012, 01:46 AM
joshofalltrades joshofalltrades is offline
joshofalltrades has a good reputation on FTE.joshofalltrades has a good reputation on FTE.
i once swapped a 9" from an 80 e150 into an 86 F150 that came with an 8.8, and that was a direct bolt up.
i'm not aware of any changed in the suspension and axles between the early 80s and late 80s, so i would expect it to fit. take a look around the junkyard with a tape measure in your hand, it might fit, it might not. but i've seen plenty of "impossible" things work
but as you mentioned in the first post, 3.73s weren't very common, so the time/effort of finding one might outweigh the cost of just rebuilding yours to the gears you want
Question on gear ratios and RPMs 2gumby2 2015+ F150 12 07-23-2016 08:26 AM
Rear axle swap in Excursion, different lengths? blloyd29 1999 to 2016 Super Duty 1 03-28-2016 07:11 PM
8.8 rear end from an explorer to and f150 Pearlwhite94 1987 - 1996 F150 & Larger F-Series Trucks 9 01-09-2015 03:53 PM
Axle/gearing questions turnkyle 1987 - 1996 F150 & Larger F-Series Trucks 11 05-17-2011 05:09 PM
Rear axle tag codes ivplay Modular V10 (6.8l) 1 07-16-2010 12:54 PM
Tags
150, 1999, 2011, 88, axel, axle, bronco, differntial, e150, end, f150, ford, forum, interchangeable, online, rear, shaft, strong
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
