Door hinge - Ford Truck Enthusiasts Forums
Door hinge
Old 03-25-2012, 11:35 PM
Glxy66 Glxy66 is offline
Glxy66 is starting off with a positive reputation.
Door hinge
How do you tell the difference between door hinges on a 56 F. How do the top and bottom differ and do they differ left to right? What should I look for? Any help would be appreciated. Thanks.
Old 03-26-2012, 07:49 AM
raytasch's Avatar
raytasch raytasch is online now
Old guy with old toys
raytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant futureraytasch has a brilliant future
I could not tell much difference when I pulled mine so I marked them with a scratch awl. I'll look today to see if I can tell any difference.
Mine are all installed but I could not see any differences in them.
Old 03-26-2012, 11:33 AM
9teen56f100's Avatar
9teen56f100 9teen56f100 is offline
9teen56f100 is gaining momentum as a positive member of FTE.
I believe they are the same, top/bottom/right/left. I bought a good set of used ones when I built my 56. I just installed them in no particular order. They worked great.
brian...
Old 03-26-2012, 12:50 PM
r_reed's Avatar
r_reed r_reed is offline
r_reed has a great reputation on FTE.r_reed has a great reputation on FTE.r_reed has a great reputation on FTE.r_reed has a great reputation on FTE.r_reed has a great reputation on FTE.r_reed has a great reputation on FTE.
i guess you could look up part numbers and see if there is one, two or four different numbers? number dummy may be able to help is he's around.
Tags
55, 63, antique, door, f100, ford, hinge, hinges, lubricating, truck, van
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
