8.8 Inch Axle and ABS
Old 03-25-2012, 10:02 PM
95e150CW's Avatar
95e150CW
95e150CW is offline
So, i am wanting to change out the 3.55 gears in the ARES 1995 E150 for a 4.10 set. MAYBE 3.73. I am just looking for a bit more passing power when pulling a 3klb trailer.
My brain says that the gear ratio shouldn't affect the tone ring, it should still turn the same number of times per revolution of the tire if I do this swap, Any opinions? If it does, should doing the ratio adjust on the PSOM correct it? I am quite sure the ABS module relies on the PSOM to send it the pulses...
donniezyea
03-18-2010 01:11 PM
Katmandu
09-09-2005 06:29 PM
LoosMaster
11-19-2003 06:34 PM
fordracer90
03-12-2003 09:47 PM
Quick Reply: 8.8 Inch Axle and ABS
