1997 F350 dually tire choices? or super single? - Ford Truck Enthusiasts Forums
Old 03-25-2012, 08:01 PM
Kirbys73F100's Avatar
Kirbys73F100 Kirbys73F100 is offline
Kirbys73F100 is gaining momentum as a positive member of FTE.
Hi, my name's Travis and I have a '97 F350 460 5 speed 2wd dually and it gets stuck real easy. I'd like to go to a larger, wider all terrain front and rear. I have a few questions and am looking for any advice.
1) What's the largest tire I can run with out spacers on the back and a lift in the front? 16" wheel
2) What budget oriented all terrain can anyone recommend?
3) Is there a such thing as a super-single setup for these trucks?
I've been looking at 235/85/16 Federal Couragia Mud Terrains (LR-e)
Thanks in advance for the help!
Old 03-30-2012, 08:56 AM
pennsylvaniabo pennsylvaniabo is offline
pennsylvaniabo is starting off with a positive reputation.
You could prolly do a 255/85/16 which is a 33/9.50 ish tire. As for a super single you will have a hard time finding a wide tire for a 16" wheel that has a good load rating.
Old 04-12-2012, 06:01 PM
nitrogen's Avatar
nitrogen nitrogen is online now
nitrogen has a brilliant futurenitrogen has a brilliant futurenitrogen has a brilliant futurenitrogen has a brilliant futurenitrogen has a brilliant futurenitrogen has a brilliant futurenitrogen has a brilliant futurenitrogen has a brilliant futurenitrogen has a brilliant futurenitrogen has a brilliant futurenitrogen has a brilliant future
all depends, what are you getting stuck in. Mud,snow, or? many times more floatation make you get stuck easier, unless you go to a much more aggressive tire. are tire chains an option?
Old 04-12-2012, 06:04 PM
we're talking in the dirt on flat ground...
Old 04-27-2012, 11:58 AM
Supercab Supercab is offline
Supercab has a very good reputation on FTE.Supercab has a very good reputation on FTE.Supercab has a very good reputation on FTE.Supercab has a very good reputation on FTE.
I wouls stick with the stock size LRE tire, just may be get something a bit more agressive....may be try adding a little weight to the bed when you feel the need to go off road...
Old 04-29-2012, 09:26 PM
Goldy3's Avatar
Goldy3 Goldy3 is offline
Goldy3 is starting off with a positive reputation.
I run Michelin ltx ms2. They are a good all around tire except MUD. They are quiet and durable in my opinion. They are a little expensive but they worked so well on my last truck that I bought 6 for my dually....
A/T or M/T? What tires you running? Aaron-71 1973 - 1979 F-100 & Larger F-Series Trucks 17 02-15-2017 04:32 PM
new (to me) 2005 f350 dually 6.0 3504x4 1999 to 2016 Super Duty 2 08-21-2014 10:04 AM
285/75/16 Bfg all terrain fit stock 16inch rims with leveling kit? 2Quik4u 1997 - 2003 F150 7 07-23-2010 09:51 PM
BFG Tires - All terrain vs Mud terrain DosMas 1999 to 2016 Super Duty 6 09-29-2005 11:23 PM
TRXUS tires? dmilkman Offroad & 4x4 9 05-10-2004 05:13 PM
Tags
16, 1996, 1997, custom, diesel, dually, f350, ford, load, rating, run, single, singles, super, tires, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
