White gauges-what not to do
I have been following the FTE trend to change the OEM instrument faces from black background with white numbers to a white face background with black numbers. To me this is a great looking modification. First I ordered a set of vinyl stickers designed to be an easy way to get the look without being an artist. I got the kit and put it on my gauges, pretty easy but did not like the look.
I then decided to tackle painting them and try a steady hand at painting the numbers by hand. Sprayed the background a glossy white epoxy paint, then went after the raised numbers with a paint pen (Sharpie brand from hobby shop). I got the very fine point pen which was a mistake-get the fine or medium point-easier to paint without as much tendency to get off raised numbers. So after 3 times with the very fine tip paint pen( re-painted background each time) the details of the gauge face was being lost from the layers of paint.
Time to get serious with getting the multi-layers of paint off the gauges with some "aircraft" grade paint stripper. This was the real mistake-DO NOT USE AIRCRAFT GRADE PAINT STRIPPER ON PLASTIC-what a messy of gooey plastic do I have left-
Anyone have tach & speedo with trip odometer gauge face for sale? Please PM if you do
Do a Google search on plastic-safe paint removers, allegedly there are plastic-safe chemicals one can use for this.
I made the mistake of dropping a blue oval in a small container of brake fluid I was using to get paint off of a toy car, and unfortunately I didn't realize until it was too late. When I pulled it out, the plastic had tiny cracks running throughout it.
As far as this being a trend, I honestly think it died down a few months after Sycostang first did his write-up. I once painted my gauge cluster, but I realized I didn't like it as much as I thought, so I went back to the original gauges.
Don't feel bad, I tried to do mine but with red background and white letters/numbers. Initially it looked great until I tried the whiteaint, then a wierd marker thing neither looked good so I repainted the red and it left a few runs, nothing major though. I then went for black numbers/symbols with a sharpie but kept messing up the Normal on the oil and temp guages. I then tried to start over and ended up melting a piece with aircraft stripper. I eventually threw in the towel and got another cluster from the junkyard.
