You are currently viewing our forum as a guest, which gives you limited access to view most discussions and access our other features. By joining our community, at no cost, you will have access to post topics, communicate privately with other members (PM), respond to polls, upload content and access many other special features. Registration is free, fast and simple, so please join our community today!
Owner of a 2005 Escape and trying to figure out which relay on the interior fuse panel is the Accessory Delay relay. I think this might be causing a battery drain when everything is shut down. A diagram of the relay side of the panel would really help.
Thanks
The manual shows the front side of the panel only, not the back side where the relays are located. i have five relays all identical and one smaller one that has failed. When supplied with a 12 volt current it does not close. Symptoms are battery being discharged when idle. having to disconnect battery to save the charge.
Why not just check continuity with a meter from the fuse to your relay socket? If a relay is defective, what doesn't work right now?
