Whats a good exhaust for me? - Ford Truck Enthusiasts Forums
Old 03-25-2012, 07:01 PM
brcwelding brcwelding is offline
brcwelding is starting off with a positive reputation.
I have an 88 f250 with a 351w. I was wondering if any of you guys have any good exhaust setups. I am not looking to do headers but let me know what you guys have.
Old 03-25-2012, 07:57 PM
rla2005's Avatar
rla2005 rla2005 is online now
rla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud ofrla2005 has much to be proud of
Factory manifolds, Bassani 3" y-pipe, 3" Magnaflow converter and muffler. Then finished off with a 3" aluminized tailpipe, please do not tell my truck it was designed for a Chevy.....
I blew my budget on the 3" stainless Bassani y-pipe, hence the reason why I am still running factory manifolds.
1992 F350 4x4 5.8L/E4OD
Old 03-25-2012, 10:37 PM
Scooter70 Scooter70 is offline
Scooter70 is starting off with a positive reputation.
I kept everything just changed the muffler.I went with a Thrush welded. Nice mellow sound.
Old 03-25-2012, 11:35 PM
GNR22's Avatar
GNR22 GNR22 is offline
GNR22 has a good reputation on FTE.GNR22 has a good reputation on FTE.
My last set up on my 351w was stock manifolds, stock piping up to where it was supposed to be a y. Made a better flowing y pipe into 3" pipe then into a 3" single in single out flowmaster 50 series and a 45 out behind the passenger rear tire. Sounded like a mustang with a 302 if you cut off the exhaust after the cat on it. No crackle or pop. Mellow under 3000 rpms and a nice roar after that.
My current set up is a set of long tube 3" collector dynomax headers into a 3" single in single out summit street and strip muffler then it goes to a 45 degree angle out before the rear tires. Sounds a lot meaner and lower, but still decent at low rpms. The headers with the full 3" pipe and lack of tailpipes freed up a ton of power. You can tell a difference in the seat as well as in the pocket. gained 1 mpg average swapping to the current set up.
Old 03-26-2012, 06:19 AM
I like the y pipe into the 3 inch pipe. If i fid that i would probably use a flowmaster 40 and just cut the cat off. Anybody have a good dual exhaust setup.
Old 03-26-2012, 10:27 AM
GNR22's Avatar
My current exhaust is dual. I should have been more descriptive.
Old 03-26-2012, 11:29 AM
Midnite1987's Avatar
Midnite1987 Midnite1987 is offline
Midnite1987 is a splendid one to beholdMidnite1987 is a splendid one to beholdMidnite1987 is a splendid one to beholdMidnite1987 is a splendid one to beholdMidnite1987 is a splendid one to beholdMidnite1987 is a splendid one to beholdMidnite1987 is a splendid one to behold
I cut mine off just before the cat ran a piece of 3" pipe into a 3" in flowmaster super 44 and a 3" turndown directly after muffler which is just infront of the rear axle.
Search "thebudmiester" in YouTube i have some exhaust clips there
Old 03-26-2012, 11:38 AM
Ole' gray's Avatar
Ole' gray Ole' gray is offline
Ole' gray is starting off with a positive reputation.
Mine is catless, factory piped into 2 cheap glass pack, rumbles at an idle, and roars past 3k, easy and doesnt sound bad
Old 03-26-2012, 03:32 PM
Edgethis's Avatar
Edgethis Edgethis is offline
Edgethis has a great reputation on FTE.Edgethis has a great reputation on FTE.Edgethis has a great reputation on FTE.Edgethis has a great reputation on FTE.Edgethis has a great reputation on FTE.
I have pacesetter full length headers, custom Y pipe with magnaflow cat and a super 44 dumped after axle.
95 zebra bronco 351w headers exhaust - YouTube
Old 03-27-2012, 08:32 PM
What do you guys think of a y pipe into a single 3" then a single in single out magnaflow muffler then dump it in front of the rear wheel.
Old 03-27-2012, 09:49 PM
rla2005's Avatar
There are a bunch of exhaust sound clips of different combinations here: Exhaust sound clips - FSB Forums
Old 03-27-2012, 09:51 PM
05victorylly's Avatar
05victorylly 05victorylly is offline
05victorylly is starting off with a positive reputation.
I run a 2 1/4" -> 3" flowmaster y pipe with flowmaster 40 series muffler. No cat
Old 03-27-2012, 10:13 PM
GNR22's Avatar
Quote:
If I were you, I would get the exhaust out from under the truck. As in aim it out the side somewhere or out the back. The single 3" will bring up torque though.
Old 03-27-2012, 10:19 PM
Ddaybc's Avatar
Ddaybc Ddaybc is offline
Ddaybc is starting off with a positive reputation.
I've got a 94 with a 5.8 and factory manifolds, Y pipe and cat. 3" from the cat to a magnaflow and then 3" out to the rear of the truck. Sounds great and I make good power. It's a simple and inexpensive exhaust. Not sure if the truck gained any extra mileage with my setup as my dad did it before he gave me the truck.
Dave
Old 03-28-2012, 12:41 AM
Quote:
Mines dumped right infront of the rear axle. The closer to the end of the exhaust (right before the dump) the louder it will be as well. Mine dumps right after TW muffler
Exhaust brake mwillmont 2017 Super Duty 13 12-07-2016 09:31 AM
5" brandon.edwards 6.0L Power Stroke Diesel 10 04-21-2014 09:15 AM
Exhaust Help TRFord 6.2L V8 20 07-30-2012 05:58 PM
exhaust frankinstien ford 1973 - 1979 F-100 & Larger F-Series Trucks 3 08-17-2011 08:41 PM
exhaust question so9956 Lightning, Harley-Davidson F-150, Roush F-150 & Saleen F-150 8 02-23-2006 07:03 AM
Tags
351, 73, 89, 94, 95, crackling, exhaust, f250, ford, fords, good, muffler, pacesetter, pipe, truck, v6
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
