Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 1997 - 2003 F150
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1997 - 2003 F150 1997-2003 F150, 1997-1999 F250LD, 7700 & 2004 F150 Heritage SPONSORED BY:
  #1 (permalink)
Old 03-25-2012, 10:30 AM
kamanjim kamanjim is offline
Garage is empty, add now
kamanjim is starting off with a positive reputation.
fuel injector replacement
Hey everyone...I have a 99 f 150 with a 4.2 V6....any tricks or shortcuts to replacing the injectors?? Intake has to come off too?
Thanks for any suggestions
  #2 (permalink)
Old 03-25-2012, 10:42 AM
KhanTyranitar's Avatar
KhanTyranitar KhanTyranitar is offline
KhanTyranitar has a good reputation on FTE.KhanTyranitar has a good reputation on FTE.KhanTyranitar has a good reputation on FTE.
If you have a bad injector, you should really get all 6 cleaned and flow matched. I have died replacing just one injector before, the problem is all of hem have the same mileage and same wear and tear, and if the old ones are partly plugged or don' have a good spray pattern, you get uneven cylinders, and that can cause new problems.
  #3 (permalink)
Old 03-25-2012, 10:45 AM
Yes, that is a good idea....makes sense to do all 6....just wondering how time consuming it will be.
Tags
1997, 1999, 2000, 2004, 42, expedition, f150, ford, fuel, fule, injector, replace, replacement, replacing, v6, warranty
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
