Stereo wiring diagram - Ford Truck Enthusiasts Forums
Old 03-25-2012, 10:28 AM
irishhandyman's Avatar
irishhandyman irishhandyman is offline
irishhandyman is starting off with a positive reputation.
Folks I have sat here for 2 hours looking for the radio wiring codes for a 95 f250. I went into the archives and cant seem to find what I am looking for. My radio was stolen a few nights ago and now I am forced to figure out the rats nest left behind. For some reason on some of the old posts the pics have been removed. As it stands I have a total of 16 wires to figure out. I am sure the answer to my question is on here some where, but I cant find it. Any help would be very much appreciated.
Thanks in advance.
Old 03-25-2012, 10:39 AM
johnvosh johnvosh is offline
johnvosh is starting off with a positive reputation.
1995 Ford F Series Stereo Wiring
Constant 12V+ Green/Yellow
Switched 12V+ Yellow/Black
Ground Red or Black
Illumination Blue/Red
Dimmer n/a
Antenna Trigger n/a
Antenna Right Front
Front Speakers 5 1/4" Doors
Left Front (+) Orange/Green
Left Front (-) Black/White
Right Front (+) White/Green
Right Front (-) Black/White
Rear Speakers 6" x 8" Side Panels
Left Rear (+) Pink/Green
Left Rear (-) Pink/Blue
Right Rear (+) Pink/Blue
Right Rear (-) Green/Orange
Source: http://www.the12volt.com/installbay/...etail/871.html
deljac's Avatar
deljac deljac is offline
deljac is gaining momentum as a positive member of FTE.deljac is gaining momentum as a positive member of FTE.
so they cut your factory ends off? hit up your local jy and get 2 new ends and wire them in. my local jy would only charge $2 for them. easy fix
Old 03-25-2012, 10:43 AM
Man that was quick! Thanks. As far as the cut ends, they were already cut. It had a Sony originally so the factory end was gone when I got the truck. Thumbs up to John. Thanks again. Now to put in an Alpine with razor blade at the back and bottom. They may get the radio, but I will have their blood! LOL
Stock Radio Upgrade oldbleu 1957 - 1960 F100 & Larger F-Series Trucks 8 10-06-2016 01:52 PM
Radio wiring 264WSM 1987 - 1996 F150 & Larger F-Series Trucks 10 07-07-2014 08:53 AM
Radio installation 86 f-150 RangerDude17 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 5 01-25-2014 05:38 PM
Radio wiring kedwinh 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 10 08-05-2011 09:59 PM
how do you remove factory radio?!?!?! powerstroker100 1987 - 1996 F150 & Larger F-Series Trucks 10 08-07-2010 11:54 PM
Tags
03, 2003, 2004, 2012, 95, diagram, door, f150, f250, ford, oem, radio, speaker, stereo, truck, wire, wiring
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
