Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
F-700 front leaf spring mods?
Old 03-25-2012, 01:01 AM
80broncoman's Avatar
80broncoman
80broncoman is offline
I have a slight delima, I am wanting to drop the ride height about a inch to level the vehicle AND I'm hoping to soften the ride slightly.
The truck has a 10K rated front axle and springs with 9 leafs(4 inches wide) on each side.
Current weight on the front axle is 5400 lbs and this is without the trailer hooked to the back of the truck. (it has plenty of tounge weight for stability, look in the bottom 2 pics)
(Total Truck weight now is 13,600 lbs with 100 gallons of fuel. Truck GVW is 32,700 lbs.)
What I am thinking of doing is cutting the ends off the bottom two leafs on both sides with a cut off wheel. I feel with the weight so low compared to the capicity of the springs that is what is making is ride so harsh.
this pic is stock height. I did remove some 2.5 iron blocks to drop it some but its just not quite level.
with blocks removed, everything else stock
Truck hooked to Trailer.
Think this is a ok move. ??
Old 03-25-2012, 01:08 PM
cj06's Avatar
cj06
cj06 is offline
pull the bottom leaf out !
Old 03-28-2012, 10:22 AM
wmjoe1953's Avatar
wmjoe1953
wmjoe1953 is offline
No, no , no, what you need to do, is come over here to Oregon, and get this matching front, and rear Peterbilt stuff I have. It's a two leaf front suspension, and "air leaf" rear. But as cj said, you can pull the bottom leaf. Did you check those blocks you pulled out, and make sure they weren't angled? If they were, you just changed your caster angle, if not, then they are just spacer blocks (I pulled the ones out of my 74 LNT-8000 front end because they were flat on both sides, and I pulled the bottom two leaves out).
Al3xMac
08-02-2022 10:02 AM
Heinz5774
09-23-2019 05:34 PM
sandymane
03-13-2019 10:15 PM
Rico47635
11-01-2011 07:36 AM
ChargersFanInCO
1999 to 2016 Super Duty
06-22-2010 04:12 PM
Quick Reply: F-700 front leaf spring mods?
