F-700 front leaf spring mods? - Ford Truck Enthusiasts Forums
Large Truck My truck is bigger than yours. The forum for 2+ ton trucks (all years), COE's, Louisville's, Big-Job's etc.
Old 03-25-2012, 02:01 AM
80broncoman 80broncoman is offline
80broncoman is gaining momentum as a positive member of FTE.
I have a slight delima, I am wanting to drop the ride height about a inch to level the vehicle AND I'm hoping to soften the ride slightly.
The truck has a 10K rated front axle and springs with 9 leafs(4 inches wide) on each side.
Current weight on the front axle is 5400 lbs and this is without the trailer hooked to the back of the truck. (it has plenty of tounge weight for stability, look in the bottom 2 pics)
(Total Truck weight now is 13,600 lbs with 100 gallons of fuel. Truck GVW is 32,700 lbs.)
What I am thinking of doing is cutting the ends off the bottom two leafs on both sides with a cut off wheel. I feel with the weight so low compared to the capicity of the springs that is what is making is ride so harsh.
this pic is stock height. I did remove some 2.5 iron blocks to drop it some but its just not quite level.
with blocks removed, everything else stock
Truck hooked to Trailer.
Think this is a ok move. ??
Old 03-25-2012, 02:08 PM
cj06's Avatar
cj06 cj06 is offline
cj06 is gaining momentum as a positive member of FTE.
pull the bottom leaf out !
Old 03-28-2012, 11:22 AM
wmjoe1953's Avatar
wmjoe1953 wmjoe1953 is offline
wmjoe1953 is gaining momentum as a positive member of FTE.wmjoe1953 is gaining momentum as a positive member of FTE.
No, no , no, what you need to do, is come over here to Oregon, and get this matching front, and rear Peterbilt stuff I have. It's a two leaf front suspension, and "air leaf" rear. But as cj said, you can pull the bottom leaf. Did you check those blocks you pulled out, and make sure they weren't angled? If they were, you just changed your caster angle, if not, then they are just spacer blocks (I pulled the ones out of my 74 LNT-8000 front end because they were flat on both sides, and I pulled the bottom two leaves out).
1969 Highboy Crew Rebuild Thread garbz2 1967 - 1972 F-100 & Larger F-Series Trucks 30 03-06-2015 03:18 AM
My 58 F100 project RUN4CVR 1957 - 1960 F100 & Larger F-Series Trucks 136 09-06-2013 09:18 AM
New parts for "Christine II" garbz2 1961 - 1966 F-100 & Larger F-Series Trucks 12 09-11-2012 09:00 AM
My F-700 RV/jeep transport build thread 80broncoman Large Truck 45 08-11-2012 06:48 PM
New 75 f100 kcode 1973 - 1979 F-100 & Larger F-Series Trucks 5 10-03-2011 09:07 AM
Tags
duty, f700s, ford, front, gvw, heavy, inch, leaf, spring, super
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
