Bent push rod? - Ford Truck Enthusiasts Forums
Bent push rod?
Old 03-24-2012, 10:52 PM
AndeyHall's Avatar
AndeyHall AndeyHall is offline
AndeyHall is starting off with a positive reputation.
Bent push rod?
Got a friend that just put studs in his 06 350 and he said he got it all back together and everything sounds great except for he's got a chugging noise or something that sounds/"feels" like it's coming from in or near the air box and he said he searched a little on google and the results he found seemed to say mostly that it's probably a bent push rod. Any ideas? Are these easy or common to bend when doing this job?
Old 03-24-2012, 11:42 PM
BLADE35's Avatar
BLADE35 BLADE35 is offline
BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.
From what Iv read that yes a Pushrod can bend during this kinda work
The crankshaft needs to be rotated to a Certain spot before the Pushrods are installed
Cant remember what location it should be in though or why
I havent been that far into this truck but from the Gassers Iv done it dont matter what position the crank is in once you torq the Rocker Arms the pushrods/Valves go to the position they should be in
Old 03-25-2012, 12:53 AM
AndeyHall's Avatar
Thanks for the info man. I'll let him know.
Old 03-25-2012, 09:28 AM
texans's Avatar
texans texans is offline
texans is a splendid one to beholdtexans is a splendid one to beholdtexans is a splendid one to beholdtexans is a splendid one to beholdtexans is a splendid one to beholdtexans is a splendid one to beholdtexans is a splendid one to behold
http://www.ford-trucks.com/ford-manu...%20removal.pdf
Look about half way down it's on there about crank postioning
It's in the tech folder under PDF files, Then head removal.
I always rotate it to the 6 o'clock position torque head down to first setp, then rotate the engine 2 full turns , ending back at the 6 o'clock postion (by hand do not use the starter) to insure there is nothing binding up if it is binding up stop right there and figure out the problem. I do this for both heads. Then once I do the final torque I rotate it again 2 full rotations just to be sure everything is good.
There are many different ideas of why the 6 o'clock postion. Some say it's not nessesary, but I have always done it, and have never bent a rod. The only thing I know about the 6 o'clock postion is that at that point none of the pistons are at TDC.
Old 03-25-2012, 09:40 AM
2006powerstroke90's Avatar
2006powerstroke90 2006powerstroke90 is offline
2006powerstroke90 has a great reputation on FTE.2006powerstroke90 has a great reputation on FTE.2006powerstroke90 has a great reputation on FTE.2006powerstroke90 has a great reputation on FTE.
After headgaskets? I bent my push rod, sounded like it was coming thru airbox...was on the pass side...
Had a 7.3 come back on a hook, same exact sound....sounded like it was coming thru the airbox....was on the pass side w/a bent push rod.
Old 03-25-2012, 10:28 AM
AndeyHall's Avatar
Ok thanks. He's wanting to know how to rotate the crank shaft, and also, he's about an hour and a half from home and he's wanting to know if it's ok to drive it home or not.
Old 03-25-2012, 11:05 AM
hmmm, an hour and a half from home is kind of a distance to drive it with a bent push rod...Im sure driving like that could cause lifter damage or even bigger damage with the cylinder not properly combusting....
Might be better off towing it....
Right off the bat, I would order the new push rod and rocker arm/assembly, I thought my rod was just bent, but the rocker was broken and I had to wait another day for parts.
Goodluck.
Old 03-25-2012, 11:09 AM
texans's Avatar
I wouldn't drive it.
To rotate the shaft, use a breaker bar and a 18MM socket on the blancer bolts turn it clockwise.
There is a tool from ford to remove the rocker arms and change push rods. I belave this is the correct one OTC , 303-1170 Rocker Arm Relase Tool
There is a certain rod that tipicaly gets bent read this thread for a better explanation on witch one and correct way to go about the problem Help! 6.0 problem after head stud install - Page 3 - Ford Powerstroke Diesel Forum
Old 03-25-2012, 11:52 AM
AndeyHall's Avatar
Thanks guys, I let him know everything and he's going to try and pull it back apart today. and see what he can find.
Just curious though...the rocker arms aren't too terribly expensive from Ford, so why does some aftermarket brand insist on pricing theirs at $2,500 on XDP?! Seems like you could go through SEVERAL factory sets before ever justifying that cost...
Old 03-25-2012, 06:38 PM
m-chan68's Avatar
m-chan68 m-chan68 is offline
m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.m-chan68 has a spectacular reputation.
...... and I vividly remember being involved in that debate. And to the OP, no I would not drive it until the issue gets resolved.
Possibility of a bent push rod? z31freakify 1994.5 - 1997 7.3L Power Stroke Diesel 42 08-22-2016 02:18 PM
How do I diagnose and replace a bent push rod? doug42190 6.0L Power Stroke Diesel 12 06-10-2016 11:25 AM
Push Rod Removal Eric Kropp Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 12 08-27-2014 12:06 PM
Pushrods keep bendind jeffmeyers351 1987 - 1996 F150 & Larger F-Series Trucks 12 06-11-2012 08:17 PM
possible bent push rod chris josleyn 335 Series- 5.8/351M, 6.6/400, 351 Cleveland 2 02-27-2007 08:01 PM
Tags
1978, 351, 360, 60l, bent, engine, fe, ford, push, pushrod, replacement, rod, rods, symptoms, tech
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
