2005 FX4 OffRoad Stuck in Park
I am a new member of FTE. My truck gear shift is stuck in Park (console type). I have been reading threads that discuss potential causes such as blown fuses, bad brake switch, bad brake shift interlock actuator, and even ignition switch. All fuses are okay. Before I try to get into all the other possibilities, I have a question around what the local auto parts worker suggested. He said that there is a small plastic piece that may have slipped down interfering with gear movement. This could make sense, especially since the white manual release lever doesn't seem to be moving.
Has anyone had any similar problem that was easily fixed w/ a slipped plastic piece?
Mark is right...and I would start there. Mine clicks hard enough to feel it in the shifter when you rest your hand on it. It's pretty pronounced. Search on here for the bypass, which will allow you to shift it until you get it fixed. Requires taking the trim off and inserting a screwdriver or another means to depress a small button of sorts.
Thanks guys. Was going to replace the brake switch (do not hear clicking at the brake pedal, nor the shifter), but it was not in stock. So before I had it towed home (yep, they always break down away from home), thought I would ask about the other possibility mentioned by the parts store.
I've accessed the bypass switch, but cannot get it to move. Gonna run back up to my truck today, & have it towed home if I can't fix it quickly.
Thanks McDavis. Yes, brake lights come on. But I've also read that the brake switch has multi-connectors, so brake lights could still work while the brake switch isn't sending the signal to the shifter. Will try once more to get the bypass button to move or will have it towed home to wait
while I find an interlock actuator (not carried in the local parts store).
Just to let you know, the avalibility of a part at a parts store has no relivance to its commonality for failure... like said previous check it the way it was stated
Update: Wasn't able to get the bypass lever to release the shifter, so I had it towed home. Started dismantling everything to check it out. Removed the interlock solenoid/actuator from the shifter but did not remove the electrical connector. While holding the solenoid in my hand (in it's plastic housing), I could hear & feel the vibration from the solenoid engaging when I pressed the brake pedal.
However, there was NOT a clicking sound until I manually pressed the lever into the solenoid housing. I studied everything closer & discovered that the clicking at the shifter does not occur just because the solenoid engages. The engaged solenoid lowers the bypass button, but the clicking ONLY occurs when the shifter raises and presses the release lever into the solenoid housing.
My shifter would still not raise & move out of Park, so I dismantled the upper end of the shifter **** and discovered that the plastic housing inside the **** was broken. Although the shift button would depress, the broken plastic was causing the pin not to engage with the shifter itself.
So, tomorrow will find a replacement shift **** and put everything back together.
Good news, in the long run is a fairly simple fix....biggest expense will be the tow cost & my time. But I've learned a lot in the process, too.
No luck finding an aftermarket replacement. Shopping on internet for OEM...local Ford dealer can order one for ~$65. Seriously, $65 for that piece of cheap plastic crap that will inevitably break again?
If anyone learns of an aftermarket replacement, please let us know. Thanks!!
