Harmonic Balancer E4TE-B3A - Ford Truck Enthusiasts Forums
Old 03-24-2012, 05:17 PM
mikepedersen17 mikepedersen17 is offline
mikepedersen17 is starting off with a positive reputation.
Question Harmonic Balancer E4TE-B3A
I have a 1985, 351W out of a F-150 pick-up I am rebuilding, I am going to have the rotating assembly balanced, the harmonic balancer E4TE-B3A is kinda ratty looking so I am planning on replacing it I believe it is an external balance and it has 4 bolts can any one tell me if it is 28oz. or 50oz. I've Googled it but cant find how many ounces, I've also looked it up on Jegs and Summit just want to make sure I get the right one. would appreciate any help. Thanks
Old 03-25-2012, 12:40 AM
Beanscoot Beanscoot is offline
Beanscoot is gaining momentum as a positive member of FTE.Beanscoot is gaining momentum as a positive member of FTE.
All 351W engines were 28.2 oz-in. imbalance.
Old 03-25-2012, 12:24 PM
Thank You, Beanscoot
Old 03-25-2012, 04:17 PM
You're welcome.
I also checked Google, and could not find conclusive evidence about that casting number, but it seemed to mostly turn up on 351 engines. And, as said previously, all 351Ws are 28.2 oz in unbalance.
By the way, dampers are acceptable even if the rubber is a bit cracked on the outside.
Old 03-26-2012, 09:46 PM
Thanks again, maybe I should just not worry about it,it is cracked a little on the rubber Im getting so much invested in engine parts I keep thinking just one more thing.
28oz or 50oz balancer Tommyrog 1973 - 1979 F-100 & Larger F-Series Trucks 18 01-12-2017 09:37 PM
Harmonic Balancer jvmcc WTB - Parts & other 1 11-08-2015 10:54 AM
351W 28oz balancer and flywheel questions eBronc3 1966 - 1977 Early Broncos 2 11-05-2015 06:38 PM
harmonic balancer pulley retired ironworker FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 2 02-27-2015 09:12 PM
1990 F150 5.8 no start after new cylinder heads benthook 1987 - 1996 F150 & Larger F-Series Trucks 10 07-22-2011 04:53 PM
Tags
04, 2004, 260, 40, 60, balancer, diesel, engine, f350, ford, harmonic, performance, recalls, removing, sohc
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
