EGR code p1335 - Ford Truck Enthusiasts Forums
EGR code p1335
Old 03-24-2012, 01:56 PM
Fordflanigan's Avatar
Fordflanigan Fordflanigan is offline
Fordflanigan is gaining momentum as a positive member of FTE.
EGR code p1335
hey guys my truck just threw P1335 and p0404. I pulled the EGR valve to check it and it is dry and sooty not sticky. I noticed a chunk missing from the o ring. Would this be a possible reason for throwing the code?
Its a new o ring as i cleaned the valve about 2000 miles ago and the valve was still relatively clean. The cel came on when I was driving, truck would only idle when accelerating after about 5 seconds of this all the sudden it would kick blow a puff of white smoke and then act normal, its done this about 3 times now since the light came on. thanks
Old 03-24-2012, 02:36 PM
BLADE35's Avatar
BLADE35 BLADE35 is offline
BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.BLADE35 has a spectacular reputation.
Yes replace the Oring and Lube the new orings with clean moter oil before install
If orings not sealing exhaust gas is Freely flowing in the Intake manafold and not being regulated
change Oring clear codes should be ok
Old 03-24-2012, 05:56 PM
Thanks Benny, thats what i figured. I was goin to replace it no matter what I just wanted to make sure it wasnt a bigger problem.
Will any o ring work or should I just get the Ford kit and install a new gasket too? Dealership is closed till Monday
Old 03-24-2012, 06:13 PM
BLADE35's Avatar
Oreilys or autozone may have a Gasket kit for it they do sell EGR Valves so they should IDK if you can get just orings or what
They do have Oring kits with all sizes in it But you will want one that can withstand high exhaust temps. Everytime I get an assortment of orings trying to find specific size there all close but none work.
IMO if you can get the specific Orings pulled upin there computer then you should be good to go If not doubt the assortment kit will work for you
Old 03-24-2012, 10:23 PM
ok ill give oreily's a shot. Thanks again
Old 03-25-2012, 08:38 AM
npccpartsman's Avatar
npccpartsman npccpartsman is offline
npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.npccpartsman has a spectacular reputation.
Those are EGR valve position codes, not flow codes. Sounds like it's an internal problem with the valve. If they keep coming back you're going to have to spring for an EGR valve.
Need Help - P1335 code displayed 4Snow 6.4L Power Stroke Diesel 5 01-13-2017 10:26 AM
P0404 & P1335 codes alxhockey 6.0L Power Stroke Diesel 6 06-22-2016 12:30 AM
Black Smoke on Acceleration Batt5 6.0L Power Stroke Diesel 10 06-18-2012 02:17 PM
P1335 & P0404 Codes Racin07jason 6.0L Power Stroke Diesel 2 05-08-2012 07:26 AM
Interesting (to me anyway) Information on Hot No Start XB70 6.0L Power Stroke Diesel 6 09-29-2011 12:39 PM
Tags
2005, 2008, 60, aerostar, code, codes, diesel, engine, f250, f350, ford, p1335, smoke, trouble, white
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
