Engine Monitoring using Bluetooth OBDII Port Scanner - Not Scangauge or Ultragauge - Ford Truck Enthusiasts Forums
Excursion - King of SUVs 2000 - 2005 Ford Excursion SPONSORED BY:
Old 03-24-2012, 09:56 AM
TrdLtly's Avatar
TrdLtly TrdLtly is offline
TrdLtly has a superb reputationTrdLtly has a superb reputationTrdLtly has a superb reputationTrdLtly has a superb reputationTrdLtly has a superb reputationTrdLtly has a superb reputationTrdLtly has a superb reputationTrdLtly has a superb reputationTrdLtly has a superb reputationTrdLtly has a superb reputationTrdLtly has a superb reputation
As the title states, this is for the bluetooth scanner and not for the Scangauge or Ultragauge (There are plenty of threads on those devices already). Keep in mind that while this thread is aimed specifically at the Excursion (gas and diesel), it will work on most 1996 and newer vehicles. I have been doing a little digging into how it works and what it is capable of and am leaning toward getting one soon. Wondering if anyone else has experience with these.
Bluetooth devices:
Soliport ELM 327 Bluetooth OBDII OBD2 Diagnostic Scanner Only $16.75 with FS on Amazon.
For those of you who have deeper pockets here is one from Scantool.net They do offer software called ScanXL that offers Ford Enhanced options, but appears to be all PC based.
Software for:
Android Devices:
Torque Lite - free
Torque Pro - $5
Here is a link to the Android Play (market) with a search of OBDII.
iPhone's (I am not a fan of proprietary software/devices, so someone else will have to post iPhone stuff, but I will be nice and post this one for example):
DashCommand™ for iPhone
Edit: I removed the video as it had died.
Old 03-24-2012, 09:44 PM
Curt's05's Avatar
Curt's05 Curt's05 is offline
Wiser by FTE
Curt's05 has much to be proud ofCurt's05 has much to be proud ofCurt's05 has much to be proud ofCurt's05 has much to be proud ofCurt's05 has much to be proud ofCurt's05 has much to be proud ofCurt's05 has much to be proud ofCurt's05 has much to be proud ofCurt's05 has much to be proud ofCurt's05 has much to be proud of
The 1 star reviews complained of the dropped connection with 3 of them, that i looked at, so i wouldn't buy one., I do like the concept...
Old 03-24-2012, 09:51 PM
LWW's Avatar
LWW LWW is offline
LWW has a great reputation on FTE.LWW has a great reputation on FTE.LWW has a great reputation on FTE.LWW has a great reputation on FTE.LWW has a great reputation on FTE.LWW has a great reputation on FTE.
Looks like the video has been pulled as well...
Old 03-25-2012, 07:38 AM
TrdLtly's Avatar
I found where the Torque app was talked about before: http://www.ford-trucks.com/forums/10...orque-app.html
So as Curt stated the weakness appears to be the Bluetooth (BT) adapter. In the above thread they talk about the Torque forums. Those forums may be able to recommend a BT adapter that works or that others have had success with. Have to go check those out later. If anyone finds some good input make sure you share it.
Old 03-25-2012, 01:59 PM
william_04_x's Avatar
william_04_x william_04_x is offline
william_04_x has a superb reputationwilliam_04_x has a superb reputationwilliam_04_x has a superb reputationwilliam_04_x has a superb reputationwilliam_04_x has a superb reputationwilliam_04_x has a superb reputationwilliam_04_x has a superb reputationwilliam_04_x has a superb reputationwilliam_04_x has a superb reputationwilliam_04_x has a superb reputationwilliam_04_x has a superb reputation
I'm going to order this adapter tonight. I'll let you know how it works with Razr Maxx and Moto Xoom.
Amazon.com: Bluetooth Car Code Reader Compatible with Android / Droid / Torque: Car Electronics
Old 03-25-2012, 09:41 PM
BigRy's Avatar
BigRy BigRy is offline
BigRy is gaining momentum as a positive member of FTE.
I have one and I use it on all my vehicles, including my Diesel Ex. Never had a problem with it and it gave me all the info I needed, I have since bought an EDGE insight. However, prior I never had a problem with my ELM327 Adapter. It took some time to connect, but once I got it, it worked like a champ. I used the Android Torque app also.
Old 03-25-2012, 10:25 PM
TrdLtly's Avatar
Quote:
Hey BigRy, Thanks for the input.
Did you use the one in the first post? Do you have the Torque Pro? Any suggestions?
Old 03-25-2012, 11:25 PM
BigRy's Avatar
Yep, thats the one I have. And yes as well on using Torque Pro. It was only 5 bucks, so I could live with it. There really isnt any suggestions I could offer, its pretty simple. When you plug it in, you have to enter the code which I think is either 1-2-3-4 or 0-0-0-0. Let it sync and you will see the lights start going all crazy and thats pretty much it. You can use it to data log, check gauges and such, I only used it for diagnostic purposes. Hope this helps....
Old 03-25-2012, 11:39 PM
TrdLtly's Avatar
Thanks Ryan. That does help. I am hoping to either set it up on a tablet or an old Android cell phone. I currently have 2 Android cell phones that I use for MP3 players around the house running off my wifi. I just put the phones in Airplane mode and then turn on the wifi. They work great for that and am sure that they would work great with Torque Pro.
Hoping to do a little more research on the Torque app and what can be programmed in for monitoring purposes. I did read on one forum that you can run up to 12 different monitor points at a time, but it is really slow at that point. I don't think that I would want that many, but the limitation is good to know.
Old 03-25-2012, 11:46 PM
I put together some gauges on my tablet tonight. I wouldn't want to cram this much on a phone display. I'm curious to see how many pop up and display accurate info.
There are some other really cool features in the paid version. One is the map view. It shows selected gauges over real time Google maps. Another is track recorder which shows selected gauges over images from your devices video camera and Google maps. Both have record features. Looks like fun.
Old 03-25-2012, 11:54 PM
TrdLtly's Avatar
Looks like a instrument cluster in a plane. Ready for takeoff. That is awesome. I may have to set up the tablet instead of the cell phone. LOL. Thanks
Old 03-26-2012, 12:27 AM
BigRy's Avatar
Wow... I just had mine on my Evo. If you have any hiccups, there is a wikipedia page that offers troubleshooting tips. Good Luck.
Old 03-26-2012, 07:41 AM
tdappleman tdappleman is offline
tdappleman is a name known to alltdappleman is a name known to alltdappleman is a name known to alltdappleman is a name known to alltdappleman is a name known to alltdappleman is a name known to all
I've been thinking about doing something similar. I've got a code reader and a Snap On Solus Ultra at the shop but wanted something I could leave in the truck. Be a cheap way to monitor things on the tablet or the phone. Got mine on order - now to find a decent way to mount the tablet in the truck!
Old 03-26-2012, 08:06 AM
TrdLtly's Avatar
Quote:
I love this idea, but a little narrower.
Old 03-26-2012, 05:06 PM
AzPatMan's Avatar
AzPatMan AzPatMan is offline
AzPatMan has much to be proud ofAzPatMan has much to be proud ofAzPatMan has much to be proud ofAzPatMan has much to be proud ofAzPatMan has much to be proud ofAzPatMan has much to be proud ofAzPatMan has much to be proud ofAzPatMan has much to be proud ofAzPatMan has much to be proud ofAzPatMan has much to be proud of
William - Which app did you use with the Xoom?
Torque?
OBDII Monitors - Some General Info Rusty Axlerod 6.0L Power Stroke Diesel 29 06-23-2015 04:28 PM
Samsung S5 and Torque App with ELM327 4x4pwr Modular V10 (6.8l) 10 02-08-2015 10:02 AM
The ELM327 diagnostic tool for your smartphone joegeds 1987 - 1996 F150 & Larger F-Series Trucks 5 11-04-2014 11:41 AM
OBDII bluetooth or wifi Gunny77 6.7L Power Stroke Diesel 4 02-06-2014 09:49 AM
My boost gauge solution tspangle84 2009 - 2014 F150 3 03-06-2012 07:04 PM
Tags
2007, bluetooth, diesel, droid, engine, ford, hybrid, ii, monitor, monitoring, obd, obd2, scanner, superduty, taurus, truck, ultragauge, works
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
