Advice? Installing flywheel and clutch behind 351W
A little bit of emory cloth tape, with some wd-40, or extra fine sand paper, or steel wool should clean up the hole fine. Make sure to wipe down flywheel afterwards with brake cleaner. Follow up with a dab of grease to ease installation, but not too much as it can heat up & spin out onto the flywheel face, causing clutch slip.
This is a pivot bolt for a T-5. Think fulcrum that the arm (lever) which actuates the clutch "rocks" back & forth on. I didn't see one in the picture of the inside of the bellhousing.
1979-04 Mustang Clutch Fork Pivot Stud, T5, T45, Tr3650 by Ford - Free Shipping at LatemodelRestoration.com
(On edit....)
MAN! Are you even OLD enough to drink beer?...
(On edit....)
(On edit....)
(On edit....)
Thanks for the info Dave. I'll get that pilot bearing hole and the bearing taken care of. My clutch has an internal hydraulic throw out bearing, so no fork or pivot arm. As for old enuf for beer, alas, yes. By about 2 1/2 decades. The pictures are of my son, not me. This truck is eventually going to be his and he is putting in quite a bit of work on it...and some of his buddies too.
t
t
Thanks Bill! Got your message the other day. Yeah we need to get you over hear to check it out. And I mean that literally. To CHECK it out. Make sure I have not done anything glaringly stupid. I think it's ironic that I, as a pilot, didn't know I needed a pilot bearing You free this afternoon?
t
t
......NORTH 45 degrees EAST.... I forgot you are a pilot!
Hang in there Ty! Looks like you are doin great! Great pics too! and the Corona on the frame...That is worth "framing" and hanging on the wall !
Another question/comment...I was looking at the pics. do I see washers on the flywheel bolts? I have never seen washers used on the flywheel bolts.
i am not sure about that one..I am not saying they can't be used, but never has any flywheel bolt, that I have had, ever had washers.
Somebody else verify that?
Question: Is the plate application-specific? It came off this engine, but my old tranny was an automatic w a flex plate rather than a fly wheel. Also I'm going to replace the starter with a new one. Do I need a new plate because of all that, or will my old one work regardless?
Thanks! Tyler
LOL good one! Pilot "bearing". yeah you probably expected something like
T
#28
#29
#30
