F100 MPG
F100 MPG
Hi,
I recently bought a 1961 f100 and have been driving it daily for about 2 weeks now. When I filled up for the first time I calculated that i got about 7 miles per gallon. Is this about what you guys are getting in your trucks? The truck has a rebuilt 302 out of an 86 mustang LX, 500 cfm edlerbrock carb and AOD transmission out of the same mustang. The rear end is stock to the 2 wheel drive truck. I thought I would be getting at least over 10 mpg.
If this is not normal what kind of things should i be looking at to improve this? I am very new too classic car and trucks so any help would be greatly appreciated.
Kimberton, One other thing, your speedo may be off now that you are running a much different tranny. You may need to change your gear tooth count.
Got a smart phone? Some of them can have GPS speedo apps that you can run to check it against your trucks clock.
With proper gearing, toothing, etc, you should be able to see 15+mpgs.
John
John
Thanks for all the ideas guys. Its a stock 5.0 that was rebuilt with after market cast pistons but other than that its stock compression cam and heads. One thing I have been having trouble with is that it will not heat up properly when im moving (it has been pretty cold) so im going to block off half of the radiator today to see if it gets up to operating temp and stays there.
I Don't have a smart phone but Im sure i can borrow one and check the speedo. Didn't think about the fact that my mileage driven could be wrong when calculating MPG lol.
what gears are in the rear? my 65 with a 390 c6 auto and a dana with trac- lok has 3.55 gears. i get about 10 mpg when i'm wearing sneakers
