53 Air Dam and 55 Radiator Support on a 55 F100 - Page 2 - Ford Truck Enthusiasts Forums
Old 06-10-2014, 10:56 PM
TxF100's Avatar
TxF100 TxF100 is offline
TxF100 is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by crewchief99 View Post
I have a 55 an trying to out the air deflectors on but its not working. It keeps hitting the x on the radiator support. am i doing something wrong?
The reason they don't fit is most likely you are trying to use 53 deflectors. I had the same issue with my truck and I ended up just getting a set of 55/54 deflectors.
Old 06-10-2014, 11:05 PM
crewchief99 crewchief99 is offline
crewchief99 is starting off with a positive reputation.
Quote:
i thought that they are the same 53-55? i was looking at new ones to see if they were a different year. i was looking in the sacramento vintage ford catalog an it was showing the fit the same?
Old 06-11-2014, 01:29 AM
fordman75 fordman75 is offline
fordman75 has a great reputation on FTE.fordman75 has a great reputation on FTE.fordman75 has a great reputation on FTE.fordman75 has a great reputation on FTE.fordman75 has a great reputation on FTE.fordman75 has a great reputation on FTE.
Look at the picture of the red fenders I posted earlier. If you look at the air deflectors they have two raised sections at the radiator opening where they sit over those X-braces. The 53 air deflectors don't have those raised areas. They are just flat.
Oh yea if anyone needs a pair of 55 air deflectors I still have the ones in that picture I'd be willing to sell. Just send me a PM.
Old 06-11-2014, 05:00 AM
truckeemtnfords truckeemtnfords is offline
truckeemtnfords is a splendid one to beholdtruckeemtnfords is a splendid one to beholdtruckeemtnfords is a splendid one to beholdtruckeemtnfords is a splendid one to beholdtruckeemtnfords is a splendid one to beholdtruckeemtnfords is a splendid one to beholdtruckeemtnfords is a splendid one to behold
You are partially right 54 and 55 deflectors will work on a 53 but not the other way around.
Old 06-11-2014, 08:12 AM
AXracer's Avatar
AXracer AXracer is offline
AXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud ofAXracer has much to be proud of
Quote:
For clarity: the 53 radiator support horse shoe did not have the X rod braces, The 54-56 horse shoes do have the braces.
The 53 deflector panels did not have dimples to clear the X rods. The 54 and 55 deflectors had the dimples but were flat behind the headlights. The 56 deflector panels have hemispherical recesses behind the headlights since the 56 grill places the headlights further into the grill opening requiring the recesses for clearance of the back of the headlight bulb.
All deflector panels 53-56 are the same size, shape (except as noted) and bolt hole locations, so it is possible to mix and match the deflectors, radiator supports and grills from the various years as appropriate. i.e. 53 deflectors must be used with 53 radiator support and 53-55 grill can be used. 54-56 deflectors are required to be used with 54-56 radiator support and 53 -55 grill may be used. The 56 grill is a special case that require that the 56 deflectors be used. The rubber isolator pads under the radiator support should be matched to the year of the support. Minor re-drilling may be required for these isolators if the radiator support and frame are of different years.
Totally confused yet?
Old 06-11-2014, 08:32 AM
sdetweil's Avatar
sdetweil sdetweil is offline
sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.sdetweil has a spectacular reputation.
the holes in the air deflector for mounting the grill are in a different location on the 56 vs the earlier models.
Midfifty sells a deflector with both hole sets..
Old 06-11-2014, 08:47 AM
AXracer's Avatar
Clear as mud!
Air dam. Metz22 1999 - 2003 7.3L Power Stroke Diesel 3 07-12-2016 08:42 PM
Front Air Dam on 93 F-150 Fordication 1987 - 1996 F150 & Larger F-Series Trucks 10 04-17-2016 08:07 PM
a/c line routing with a full flip front end jniolon Cooling, Heating, Ventilation & A/C 0 02-17-2016 08:38 AM
will 08 up air dam fit 05-07 kengarchow 1999 to 2016 Super Duty 1 07-17-2014 08:24 AM
Air Dam Modifications (Lightning) TexasGuy001 1987 - 1996 F150 & Larger F-Series Trucks 18 08-03-2006 05:32 AM
Tags
1956, 53, 54, 55, 56, air, chrome, deflectors, f100, installed, radiator, support, valance
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
