360 with 429 heads ???????? - Ford Truck Enthusiasts Forums
Old 03-23-2012, 04:13 PM
68 f250 68 f250 is offline
68 f250 is starting off with a positive reputation.
i just bought this 360 with 35000 out of a motor home to replace my 390....and i had the guy do the gaskets on it cuz all he works on is fords...and he said it has 429 heads on it is that possible.
Old 03-23-2012, 05:47 PM
jowilker's Avatar
jowilker jowilker is online now
jowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to beholdjowilker is a splendid one to behold
Quote:
Absolutely NOT. A very different bolt pattern.
428, very well could be, but not 429.
John
Old 03-23-2012, 06:52 PM
ya but thier both fe motors so y would the bolts be different..
Old 03-23-2012, 07:00 PM
Rogue_Wulff's Avatar
Rogue_Wulff Rogue_Wulff is offline
Rogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to beholdRogue_Wulff is a splendid one to behold
429 is not an FE. 427 and 428 are.
If I'm not mistaken, the 429/460 have different bore spacing than an FE. That alone would prevent the possibility of swapping the heads.
Old 03-23-2012, 07:52 PM
but its not a normal 360 cuz it was made 4 a motorhome
Old 03-23-2012, 08:26 PM
Ford_Six's Avatar
Ford_Six Ford_Six is offline
Ford_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputation
429/460 has a different bore spacing, and the interface between the intake and head is very different. The pushrods on the FE are outside the head, between the intake runners, and the valve covers overlap the intake. The pushrods on the 429 are fully within the heads, and the valve covers only cover the heads.
Lead Head Lead Head is offline
Lead Head is a name known to allLead Head is a name known to allLead Head is a name known to allLead Head is a name known to allLead Head is a name known to allLead Head is a name known to all
It's not a special 360. They are all the same. They aren't going to cast a completely different block, with completely different bolt patterns and bore spacing just for a motorhome and still call it an FE 360.
Old 03-23-2012, 08:56 PM
well could thay be 428 then cuz the guy said thier not normal 360 heads
Old 03-23-2012, 09:13 PM
It's possible. Looking for casting numbers or IDs on the heads and post them here. Someone should be able to identify them.
Also, you have a keyboard that is easy to type on and contains every single letter of the English alphabet and associated punctuation. You could at least try and put some effort into your posts in exchange for our help.
Old 03-23-2012, 10:51 PM
kenny nunez's Avatar
kenny nunez kenny nunez is offline
kenny nunez is starting off with a positive reputation.
360 -429
If I remember correctly Ford made a 370 version of the 385 series that was used in the BIG trucks, Where is the Number Dummy when we need him. I am sure he can straighten this out. Kenny Nunez
Old 03-23-2012, 11:02 PM
85e150six4mtod 85e150six4mtod is offline
85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation85e150six4mtod has a superb reputation
Ford did make a 370 medium truck engine. Same stroke as the 429, smaller bore. A real pooch. Almost NOTHING from those engines interchanges with an FE, least of all the heads. IMPOSSIBLE, as noted previously, the bore spacing is 4.90" for a 370/429/460 and 4.63" for the FE.
A 360 with 428 heads, maybe. Keep in mind 428 heads are, in the run-of-the-mill passenger car application, the same as 390 heads. And in pickup applications, 390 heads are the same as 360 heads. There could be some slight differences between late '60s car heads and some pickup heads from the same era. The most common 360/390 pickup head found is the D2.. head, from 1972 and up, with hardened valve seats.
So, are there casting numbers on those heads?
Even with the most tricked out 428 SCJ heads, it is still a 360, and still a pooch. And the 428 heads did not have hardened valve seats, so in a motor home with unleaded gas, they would last about 20,000 miles, as the poor 360 would be running WOT most of the time. WOT + the buttery old seats + unleaded gas = burned valves.
Old 03-24-2012, 04:35 AM
jowilker's Avatar
68, Maybe you heard wrong, or just forgot. We aren't trying to prove your guy wrong, but there is some cornfuzion in the air.
Don't know what size motor home you got the engine from, but FT 330s, & 361s were used. They look very much like a FE but are built for heavier truck use.
John
Old 03-24-2012, 11:41 AM
ya i am going to go find some numbers on it
Old 03-24-2012, 11:49 AM
on the heads their is c8aeh on each side
Old 03-24-2012, 12:21 PM
400 .040over 400 .040over is offline
400 .040over is starting off with a positive reputation.
thoses heads r 68-70 390-428 heads
360 to a 429 JakeNail 1967 - 1972 F-100 & Larger F-Series Trucks 7 04-15-2015 03:13 PM
1975 F250 429 4v motor swap ReconAttitude 1973 - 1979 F-100 & Larger F-Series Trucks 4 07-31-2013 06:55 PM
429 heads on 460? natira121 Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 1 07-19-2011 01:07 PM
429 verses 460 zrxlover Big Block V8 - 385 Series (6.1/370, 7.0/429, 7.5/460) 20 08-29-2010 03:30 AM
429 C6 to Manual Swap Prime123 1973 - 1979 F-100 & Larger F-Series Trucks 0 03-17-2009 04:39 PM
Tags
360, 428, 429, bore, built, fit, flathead, ford, heads, motor, ported, replacing, spacing, truck, v8
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
