5th wheel hitches
You would think so, but when you cinch the 1/2" hold down bolt all the way up before you set the lock pin on the goose, it is impossible for the goose pin to engage. A little bit of common sense goes a long way, but a general lack of common sense seems to go much farther in the opposite direction!
Setup is pretty easy. Drop the hitch in place, securely latch it into the gooseneck, align hitch in bed, cinch down the small bolt then tighten the 2 U-bolts. The only real thought required in the process is the initial setup of positioning the vertical mounts front to rear on the main hitch as well setting the height. Once you have that established it is literally a 2 minute process to install or remove the hitch.
It is quite obvious that those that have a B&W think it is the greatest hitch made. Although, I thought that when I had a SuperGLide.
With the new truck though, looking at fresh hitch options since I no longer needed the slider, B&W was a contender.
But, I just do not like the concept of the weight not being on the frame "directly".
Ended up getting the factory prep as that led to several available options.
Gave me plenty of time to over think it while waiting for the truck to come in and then spring time.
Absolutely...I installed the B&W turnoverball system in the bed for a gooseneck and a Companion 5th wheel. It works excellent. I highly recommend it.
I would say that Reese Hitches is probably gonna have the best 5th wheel hitches for that. Check 'em out and see what you think... they usually have some pretty easy to follow installation instructions too.
MN_Andy
Toy Hauler Towing; Fifth Wheel & Bumper Pull
03-20-2019 07:57 PM
17 Oaks
Fifth Wheel & Gooseneck RV Towing
01-26-2017 06:52 PM
RRranch
16
01-15-2011 08:33 AM
