7.3L diesel won't stay running - Ford Truck Enthusiasts Forums
Old 03-23-2012, 02:08 PM
duckhunter88 duckhunter88 is offline
duckhunter88 is starting off with a positive reputation.
I have a 1997 F350 7.3L diesel. Recently I started having problems with it staying running. It always starts, but will die after a couple of minutes. First I replaced both batteries as they were needing replaced anyway. I took it down the highway and it kept surging and acting like it wanted to quit running. It always starts right back up, but it won't stay running. I just replaced the camshaft position sensor and that didn't fix the problem either. Any suggestions before I give in and take it to a mechanic?
Old 03-23-2012, 02:15 PM
Lazy K Lazy K is offline
Lazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to allLazy K is a name known to all
1994.5 - 1997 7.3L Power Stroke Diesel - Ford Truck Enthusiasts Forums Here is a link to the page for your engine, probably better to ask the guys there.
However it sounds like a fuel delivery problem, maybe clogged filter, maybe bad fuel lift pump, maybe bad fuel pipe connection letting air into the fuel system. The guys on that other page will know.
Good luck.
Old 03-23-2012, 02:29 PM
just posted my problem on that page. i'm new to this. thanks!
Truck won't stay running Ant Go Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 1 01-23-2017 01:20 PM
HELP PLEASE!!! Trouble Code P1670, 0381 & more Candi Dokey Excursion - King of SUVs 5 08-15-2016 10:27 AM
93 7.3idi starts but won't stay running. jkinghorn6.0 Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 15 03-12-2014 08:24 PM
Truck won't stay running-Please Help! duckhunter88 1994.5 - 1997 7.3L Power Stroke Diesel 17 04-03-2012 08:57 PM
1995 F-250 7.3L Ignition Switch Issue Lee In Leetonia 1987 - 1996 F150 & Larger F-Series Trucks 1 07-02-2011 06:58 AM
Tags
2001, 73, 73l, 97, 99, diesel, f250, ford, run, running, started, starts, stay, turbo, wont
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
