Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > 6.2L V8
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
6.2L V8 Discuss the 6.2L V8 SPONSORED BY:
  #1 (permalink)
Old 03-23-2012, 11:09 AM
superfast bob superfast bob is offline
Garage is empty, add now
superfast bob is starting off with a positive reputation.
lowering the TPMS in new 2012
So before I pick up my new KR F350 I want the dealer to lower the trigger values on the TPMS, can we do it or is this a dealer only variable? thanks bob
  #2 (permalink)
Old 03-23-2012, 12:27 PM
8iron 8iron is offline
2011 Ford F-250
8iron is starting off with a positive reputation.
It can only be done by a dealer IF you find a dealer willing to do it...I haven't found one yet. Guys with tuners have said they can change it themselves but I can't confirm that personally.
__________________
2011 F250 6.2l Lariat FX4
  #3 (permalink)
Old 03-23-2012, 03:12 PM
biz4two's Avatar
biz4two biz4two is offline
biz4two has a great reputation on FTE.biz4two has a great reputation on FTE.biz4two has a great reputation on FTE.biz4two has a great reputation on FTE.
Arrow
Quote:
So...is there a target psi you are looking for?
I ask...because I thought if you run 10 psi lower than recommended from the VIN door sticker...no alert would come on. I am pretty sure I read that here at FTE.
biz
__________________
2012 FORD F250 SD CC 156" Lariat FX4 6.2L BOSS 4x4 4.30s
2003 F250 SD SC 142" XLT FX4 V10 Auto 4x4 3.73s -- Traded
1976 F150 LWB Custom 4x4 390FE NP435 3.50s
  #4 (permalink)
Old 03-24-2012, 06:47 AM
2000silverbullet's Avatar
2000silverbullet 2000silverbullet is offline
2011 Ford F-350
2000silverbullet is a name known to all2000silverbullet is a name known to all2000silverbullet is a name known to all2000silverbullet is a name known to all2000silverbullet is a name known to all2000silverbullet is a name known to all
I thought this was going to be a larger issue for me at first, but hasn't been until I throw a set of Toyo's on it (65psi max, but will run at 50/55), my factory tires are sitting at 65psi in the rear and 70 in the front. No light.
Like 8iron said, a dealer can do, it's if they will. It's ridiculous if you ask me, the TPMS nonsense is for cars under 10k GVWR from what I've read, so for us SD owners over that, they should move it to whatever we want. They even offer TPMS delete now on the '12's (fleet only, but still....).
__________________
Matt
2011 F350 - 6.2 CC, LB, 4.30s, Lariat Ultimate pkg, FX4, Amp steps, Lockpick, AC LC6i, JL HD900/5, JL 13TW5, JL C5-570's, Bilstein 7100 stabilizer, Rancho RS9000XL's, Leveled w/ 35" Toyo M/T's and 5 Star tuned
**Sold - 2000 F250 V10, 6.5" Pro Comp, 37" Toyo MT's
  #5 (permalink)
Old 04-07-2012, 06:28 PM
Super08's Avatar
Super08 Super08 is offline
2011 Ford F-350
Super08 is a splendid one to beholdSuper08 is a splendid one to beholdSuper08 is a splendid one to beholdSuper08 is a splendid one to beholdSuper08 is a splendid one to beholdSuper08 is a splendid one to beholdSuper08 is a splendid one to behold
I managed to talk my dealer here in Canada into lowering my rear settings on my 2011. I had the rears lowered to 60 from 80. So now the alarm should go off around 55. Before the alarm would go off at 75. It really helped being able to run lower air pressure in the rears for the winter as I don't carry much weight around. Just when towing in the summer.
__________________
2012 Ram 3500 Laramie DRW
gone but not forgotten...2011 F350 CC SB Lariat 6.2 4WD 4.30's
  #6 (permalink)
Old 04-08-2012, 10:02 AM
kmonty2's Avatar
kmonty2 kmonty2 is offline
2011 Ford F-250
kmonty2 is gaining momentum as a positive member of FTE.kmonty2 is gaining momentum as a positive member of FTE.
kmonty
Just trying to figure out why you would want this. I have found that with the higher psi in the tires I get better gas millage. I did think the opposite would be true, lower would yield better results. My be with the 18" wheels with the 3.73 makes a difference?
__________________
Kevin
2011 F-250 CC, 6.2 Gas, 3.73, 4x4 w/FX4, Tuxedo Black, Steel Cloth interior,Goodyear Wrangler Duratrac's, Air Aid Intake, Bilstein 5100 shocks, Hellwig adjustable sway bar, 5 Star Tuned, Line X bed liner, X Tang Tri-Fold bed cover.
  #7 (permalink)
Old 04-08-2012, 10:09 AM
Super08's Avatar
2011 Ford F-350
Over time running 80 psi with no load will cause the center of the tread to wear out faster than the outside. It also gives you a better ride somewhat and the biggest reason is for better traction in the winter months. No load and 80 psi in your tires at -40 temps is like driving on skates. Before TPMS I used to run 45 in the rears during the winter.
__________________
  #8 (permalink)
Old 04-08-2012, 06:13 PM
militarymetal militarymetal is offline
militarymetal is starting off with a positive reputation.
I went to different tires and the little light's been on ever since. Dealer wanted to charge me a diagnostic fee. I'll live with the little light.
  #9 (permalink)
Old 04-09-2012, 11:49 AM
biz4two; I had planned on 55 or 50 as the low target pressure as I don't want the dash light on just because I'm running 68lbs and its -10 below. I can add air to haul or run softer in the winter. Running 80 all the time makes my current King Ranch ride stiff empty but 68 is smoother.
My 6.2 comes in this week so the fun of owning new begins again......bob
  #10 (permalink)
Old 04-09-2012, 08:45 PM
92f150I6's Avatar
92f150I6 92f150I6 is offline
2003 Ford F-250
92f150I6 is gaining momentum as a positive member of FTE.
Quote:
Even in my older truck, running the recommended 80 Psi in the rear when unloaded causes an extremely harsh ride, and darn nere wants to make the rear end come around when hitting any sort of rough road. I run 50 Psi all the way around, drives better, and tires wear even all the way across.
__________________
2003 F250 SD 4X4 5.4L 4:10 Arizona Beige
1987 Mustang GT
09 Challenger RT
A bunch of motorcycles, other cars, and a Quad.
  #11 (permalink)
Old 04-09-2012, 11:30 PM
biz4two's Avatar
Arrow
Understand...and agree. I also run less air in my tires with my current SD for a better ride and tire wear.
IMHO...it seems like the FORD system is not very flexible to the Owner's needs. Guess I'll find out when I receive my ordered 2012 SD 6.2L by ends month.
biz
__________________
  #12 (permalink)
Old 04-10-2012, 07:26 AM
kmonty2's Avatar
2011 Ford F-250
kmonty
Ok, after my next dill up I am going to lower my tire pressure and see how it rides. I am also going to monitor the MPG's with the lower pressure. Since I raised it to 70/65 I have been around 12 mpg in the city.
__________________
Kevin
  #13 (permalink)
Old 04-10-2012, 10:37 AM
Super08's Avatar
2011 Ford F-350
Kevin your advantage is that you have a 250 and not a 350. Your tire pressure alarms are set from the factory at the same level on your rears as is what the fronts are set at. You can lower yours down to about 55 without having the alarm go off without doing a thing. It is a bugger when you cannot get them down below 75. Mind you I don't have that problem any more. I have heard that the American dealers are stickier about changing the settings than the Canadian dealers. Something to do with the laws down there that brought TPMS into place to begin with. Have to dummy up everything for everyone to make up for the ones that are not capable of checking their tires.
__________________
  #14 (permalink)
Old 04-10-2012, 10:58 AM
kmonty2's Avatar
2011 Ford F-250
kmonty
I see your point, the 250 should ride a little better then the 350 empty. Which is why I proberly do see much of a difference with the height psi. But I do see a difference in mpg jumpwith more air. I am still going to see what happens.
__________________
Kevin
  #15 (permalink)
Old 04-10-2012, 03:30 PM
Super08's Avatar
2011 Ford F-350
Yes your mileage will improve with higher air pressure in the tires as it will lower the rolling resistance. Lower rolling resistance also equals lower traction, so like everything else it is a give and take thing. That is why I don't like TPMS on a truck as depending on what you are doing, hauling or not hauling your requirements change. With a car they pretty much stay the same.
__________________
Tags
2011, 2012, 350, 65, delete, duty, f150, f2011, f350, ford, lower, psi, set, settings, super, superduty, tool, tpms, values
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
