Sliding rear window track seal - Ford Truck Enthusiasts Forums
Old 03-23-2012, 12:01 PM
stephen.south stephen.south is offline
stephen.south is starting off with a positive reputation.
I got a sliding rear window for my truck out of the junkyard and the seals that the inner glass pieces slide on are in need of replacement. Does anyone know where I can get these? I couldn't find them on LMC.
Old 03-23-2012, 12:32 PM
AK FORD GUY's Avatar
AK FORD GUY AK FORD GUY is offline
AK FORD GUY is gaining momentum as a positive member of FTE.AK FORD GUY is gaining momentum as a positive member of FTE.
I did some searching on the internet about this last year and only really found out that it is not reproduced.
Some have had luck with using a universal channel gasket or universal windlace, but there were no real specifics.
I would remove it and take it to a local glass shop to see what they could come up with.
Good luck and be sure to post your findings.
Old 03-23-2012, 12:51 PM
mikeo0o0o0's Avatar
mikeo0o0o0 mikeo0o0o0 is offline
mikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud ofmikeo0o0o0 has much to be proud of
Run, back window glass
Fits 73-up F100-350 w/sliding rear window
Lower D0TZ-10422A20-A
Upper D0TZ-10422A36-A
I was unable to locate any of the upper runs and only one lower run. Unfortunately the dealer that has it is Bob Allen Ford. He has a reputation of really jacking up the prices on obsolete parts so be prepared.
Another thing to note, the part number they have it listed under is actually incorrect. This is a very common problem with Ford when the year ID in the part is "0". It is very often entered as the letter "O" instead of the numeric "0". They have it listed with the letter O in DOTZ.
DOTZ-10422A20-A
Bob Allen Ford, Overland Park, KS has 1 (913) 381-2999
Just to give you a little ammo incase you call them. Last list price from Ford $40.02, dealer cost $24.02
Good Luck
Old 03-23-2012, 01:11 PM
Ok thanks.
Another question. I've heard of guys putting in electric sliding windows in these trucks. Where can I get one of those?
Old 03-23-2012, 01:46 PM
Sliding rear window seals - 95 Regular Cab Glenn54 1987 - 1996 F150 & Larger F-Series Trucks 12 10-19-2016 12:49 AM
Sliding Rear Window Weatherstrip FordTruckChuck 1997 - 2003 F150 4 09-04-2016 10:50 AM
oem rear sliding window!!! AllAboutDaZ 1999 to 2016 Super Duty 12 02-28-2014 05:12 PM
removeing rear slideing window vermillion95xl 1987 - 1996 F150 & Larger F-Series Trucks 2 01-15-2014 08:09 AM
Sliding rear window seal ?..... kuch73 1973 - 1979 F-100 & Larger F-Series Trucks 1 08-29-2011 10:43 AM
Tags
79, back, bronco, explorer, fixing, ford, glass, internet, powered, rear, repairing, seal, sliding, sport, trac, vbulletin, window, windows
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
