Anti Lock Brake Install Question
I know my Anti Lock Device has gone bad and did get one at a junk yard today. I'm wondering has anyone installed one of these. I know I have to bleed it once installed. It has a line coming in from the Master Brake Cylinder and one going to the rear wheels. Should I bleed the Anti Lock first then move to the 2 rear wheels. Assuming that's the right sequence...
1987 F-350, 460 cu.in. No fuel injected.. Rear anti lock only.
A brake pedal slowly going to the floor sounds like a bad master cylinder in my experience.I had a 1980 Bronco,without RABSof course,that had the same symptoms you're describing.Replaced the master and all was well.The RABS light is always on in my '88 F250.Other than having to readjust my rear shoes(even with new hardware)every few thousand miles,they work OK.
My friend is a Master Mech. and has been one for over 40 years. He had me do a test and don't remember the exact steps now because it was over 6 months ago. It because of the test it was determined it was the Anti Lock device. Think I'll go with the guy with the knowledge.
The correct name for it is the RABS Hydraulic Control Module (HCM).
There are two solenoid operated fluid valves inside it along with a fluid dump chamber with a spring loaded piston.
When the speed sensor on the rear diff detects that both rear wheels have locked under braking, the computer closes one of the solenoid valves so that no more fluid can go to the rear brakes and opens the other valve so that fluid can flow from the rear brakes into the dump chamber and so unlock the rear brakes. The sequence is then reversed and repeated if the brakes lock again. When the braking is finished and the pedal released any fluid in the dump chamber is allowed to return to the resevoir under pressure from the spring loaded piston.
If the valve controlling fluid flow to the dump chamber is bad then fluid can flow into the chamber when the brake pedal is pressed, so giving a sinking pedal.
If you look at the end of the HCM you will see a large hex bung. Unscrew this bung (under spring pressure all the way) and remove the spring from the chamber (no fluid will come out). Replace the hex bung. Pump the pedal a few times to fill the chamber with fluid and then see if you still have a sinking pedal. If the pedal is good then the HCM is bad. If pedal still sinks then HCM was not the problem and you can replace the spring and look towards the master cyl as a problem.
Received 3,099 Likes
on
the only way i have found to get a solid pedal that does not slowly fall to the floor while sitting at a light is to eliminate the RABS module.
