Cruise Control Cable - Ford Truck Enthusiasts Forums
Old 03-22-2012, 09:45 PM
daveengelson daveengelson is online now
daveengelson has a good reputation on FTE.daveengelson has a good reputation on FTE.daveengelson has a good reputation on FTE.
Looking at 97 F250, possible purchase. Owner keeps it in pristine condition, presenting issue is the cruise control cable needs to be replaced so I was wondering if any member(s) know of a source, or perhaps familiar with a universal replacment?
Thanks, dave
Old 03-23-2012, 06:38 PM
phil6608's Avatar
phil6608 phil6608 is offline
phil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant futurephil6608 has a brilliant future
rockauto . com has the part I'm sure.
Or if one from a F-150 with a 5.4 will fit, I'll give you one. Just pay the shipping.
Old 03-23-2012, 07:28 PM
Phill, appreciate getting back w/ me. came up with a couple of p/n and then ran a search on rockauto.com and they did not have a listing. I tried calling but after few min's. decided it's getting late and perhaps try again early Sat. or Mon. a.m.
Original part # f65a9a825cb
Replacement part # f75z9a825pa
Not sure item is same for the F150 and F250; if so, and can't not locate thru Ford part supplier I certainly can send cost for shipping. I will continue the research; rockauto.com, and couple other Ford part suppliers. Again, thank you!!. .
Old 03-24-2012, 01:47 PM
Seems there are 2-3 versions of the 97 -99 Cruise control cable and the VIN is required to determine if it's the correct version. Considering the item is discontinued it will be like looking for Hen's teeth, Only Ford!!! Looks like I will have to get back into the Sunday morning salvage shopping routine. Again, thank you!!. .
Old 05-29-2012, 12:13 AM
Super_Xtreme Super_Xtreme is offline
Super_Xtreme is starting off with a positive reputation.
I noticed a plug on the brake pump disconnected and a fuse broken near this connector.I have a code B1226 on.
Is this cable the one for the cruise control?
If not, where is the cruise control cable located?
95-97 f250/f350 cruise control servo and cable swampthing WTB - Parts & other 2 09-14-2015 09:09 PM
Cruise Control Carburetor Linkage problem Mother_Love 1978 - 1996 Big Bronco 4 05-07-2015 09:16 AM
75 High boy cruise control conoso 1973 - 1979 F-100 & Larger F-Series Trucks 23 09-27-2012 11:12 PM
Cruise Control -- Fixed! Eric H Excursion - King of SUVs 5 05-21-2011 09:12 AM
Replacement OEM Cruise Control Cable '92_Nite 1987 - 1996 F150 & Larger F-Series Trucks 0 03-03-2006 11:17 AM
Tags
1997, 2001, 97, 99, cable, control, cruise, crus, escape, expedition, f150, f350, ford, remove, t18, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
