Wheel crooked after drag link replacement
Hi folks,
I recently replaced my drag link which was loose and clunking around. I noticed my steering wheel is pointed at 11 while driving straight now. I'm not sure if it was like that before, the vehicle was new to me when I did most of the initial work.
It looks to me like I should be able to just adjust the drag link turnbuckle to change the steering wheel position but I'm not sure. Is that okay to do?
Thanks in advance,
-Brad
Thanks in advance,
-Brad
That's all the encouragement I needed. I ran out and adjusted it real quick. One turn "shorter", which may have actually been too much. I did three turns before retightening and checked the steering wheel, it had way over corrected. So one turn is all I did.
If the one turn was too much, I'll move it back half a turn. I guess I was pretty close in my original replacement measurements.
I think it helped the wander quite a bit, mostly because it made my steering a lot more responsive and accurate. Now slight corrections are adequate at highway speeds. The damn thing is still a chore to drive but its worth it to have the biggest thing on the road and it keeps me awake!
The improvement was most noticeable at low speeds. I didn't realize how loose the steering was. After the drag link R&R, my steering was much improved. I just wanted the clunk to go away. The improved steering/wander was just a welcome side benefit.
Thanks!
Thanks!
Great write up on how to center the steering wheel!
https://www.ford-trucks.com/forums/7...with-pics.html
UPDATE. One rotation was TOO much. My wheel was now pointing at 1 o'clock.
Half a turn back. I'll see if that does it. Correcting this wheel is like a Newton-Raphson root solver...for you nerds out there.
Can you educate me? I've heard this before but don't understand it. I understand the relationship between the steering column, pitman arm, draglink, and steering knuckle. But I do not see how adjusting that connection can mess up the camber or toe. The tie-rod sure...but the drag link? What am I missing?
Cheers,
-B
Cheers,
-B
I'll be replacing mine soon as well.
Kongerup
1999 to 2016 Super Duty
09-13-2020 09:26 PM
