4.9 Offenhauser, Edelbrock 500, Headers, but power lacks... - Page 2 - Ford Truck Enthusiasts Forums
Old 03-26-2012, 10:50 AM
sunnybottomboys.de sunnybottomboys.de is offline
sunnybottomboys.de is starting off with a positive reputation.
Can you explain what a heat plate is ? I did not install the whole stuff by myself :and I`m not sure if the heat plate`s done...
Old 03-26-2012, 11:01 AM
BigBlue88 BigBlue88 is offline
BigBlue88 is starting off with a positive reputation.
Search the inline six forum for "intake manifold heat".
Old 03-26-2012, 11:09 AM
1983F1503004x4 1983F1503004x4 is offline
1983F1503004x4 has a very good reputation on FTE.1983F1503004x4 has a very good reputation on FTE.1983F1503004x4 has a very good reputation on FTE.
Quote:
This was posted in your other thread you put up in the 80 to 86 forum (as well as my responses to your question about the heat plate).
Use the search function.
Old 03-27-2012, 09:38 AM
Manifold heat plate
How does the manifold heat plate look like ? What kind of material ist it ?
Are the aftermarket available ? Do you have a picture of it ?
Thank you !
Scott
Old 03-27-2012, 09:40 AM
Sorry, didn`t see you already replied at the other thread.
Old 03-27-2012, 01:22 PM
F-250 restorer's Avatar
F-250 restorer F-250 restorer is offline
F-250 restorer has a good reputation on FTE.F-250 restorer has a good reputation on FTE.F-250 restorer has a good reputation on FTE.
This is what the manifold heating plate looks like. You cut one of your heating core lines and hook one end to each of the hose fittings, bolt the thing to the bottom of the Offenhauser 'C' or 'DP' with a gasket, and it keeps your Air/fuel mix nice and toasty.
*I notice that the old Clifford intakes had a hollow spot underneath them like the Offenhauser does for this purpose, but the Cliffy uses 4 bolts, and, I believe, the Cliffy holes are blind, and don't go all the way through.
Old 03-27-2012, 04:29 PM
THAAANKS !!!
Old 03-27-2012, 05:15 PM
Leddyledford Leddyledford is offline
Leddyledford is starting off with a positive reputation.
Alright I got the new manifolds in today and after some grinding they fit but the studs w it do not fit the block. The old manifold just had bolts and huge *** washers. Anybody know were I can get the right size studs?
Old 03-28-2012, 07:53 AM
Alright. Got the new efi manifolds in and after some grinding they fit. The manifold studs do not fit in the block. The old manifolds had bolts w huge washers. Not sure if that's stock. Any idea Were I can get the right size studs? I've hit all the local part stores and no luck
Old 05-24-2012, 08:35 PM
The_SnowMan710's Avatar
The_SnowMan710 The_SnowMan710 is offline
The_SnowMan710 has a good reputation on FTE.The_SnowMan710 has a good reputation on FTE.
Quote:
Originally Posted by Harte3 View Post
"Did you install a manifold heat plate?" X2 If you didn't do that you are going to be chasing your tail to no avail.
Where does a guy get one of those manifold heat plates? I don't have one but I might as well try it since I've been having all of these same issues too. I need to read into recurving my distributor as well. With my 300 (see signature) the vacuum advance sends the timing all over the place and it won't run very good at all. Leaves me pretty disappointed for the amount of time and money I've put into it, really. I've tried setting the static timing from dead 0 all the way to 16*, same result every time, regardless of if it is plugged into the advance port or manifold vacuum. I've also tried setting the timing with a vacuum gauge as well as my digital gun. The advance sends it sky high and the motor bogs/misfires/pre-ignites. Would the flat tops I put in it mess with the compression ratio in such a way that it makes it this hard to time it?
-Kenny
Old 05-24-2012, 08:37 PM
oops, sorry! Didn't see there was a 2nd page to this before I posted! That takes care of half my question, then!
-Kenny
Old 05-26-2012, 08:52 AM
fordboy300 fordboy300 is offline
fordboy300 is starting off with a positive reputation.
Does anyone have the measurement to make of those heating plates.
  #28
Old 05-27-2012, 04:21 PM
hgb4x4's Avatar
hgb4x4 hgb4x4 is offline
hgb4x4 is starting off with a positive reputation.
Quote:
I haven't seen those posted for this myself but cant be to hard to fab one up tho, some great pics about from a few peeps here....
any fab/weld type shop prob make ya one for like 20 bucks or so
  #29
Old 05-27-2012, 05:55 PM
BaronVonAutomatc's Avatar
BaronVonAutomatc BaronVonAutomatc is offline
BaronVonAutomatc is gaining momentum as a positive member of FTE.
If you buy a Fel-Pro intake/exhaust gasket set they include the gasket that goes between the manifolds - it is a perfect template for the heat plate.
Edelbrock 500 CFM question....help? POL_Sarge Ford Inline Six, 200, 250, 4.9L / 300 6 12-31-2015 10:12 AM
300 4 barrel conversion? cloudflare 1961 - 1966 F-100 & Larger F-Series Trucks 3 08-23-2015 01:24 PM
4.9L offy "c" intake or edelbrock 1bbl intake TheDudeAbides WTB - Parts & other 0 07-14-2014 10:59 AM
Edelbrock 500cfm, Offenhauser, Headers, but no power gain... sunnybottomboys.de 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 28 03-27-2012 09:23 AM
dual quad vs. single carb? imlowr2 Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 8 08-09-2008 11:19 AM
Tags
300, 49, 500, 67, accel, carburetor, curve, edelbrock, f150, ford, headers, kit, offenhauser, setup, wtb
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
