Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Modular V8 (4.6L, 5.4L)
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 03-22-2012, 03:11 PM
FordGuy85's Avatar
FordGuy85 FordGuy85 is offline
1999 Ford F-250
FordGuy85 is starting off with a positive reputation.
99 5.4l issue. See if you can unstump!
Hello people!
I have a 99 5.4L that I got 2 years ago. At that time I added a new fuel filter among other things. Anyway the problem that I am having has stumped me since iv owned the truck but now its getting worse so I need to ask you experts.
I get up each morning and start the truck cold. It starts normal. Turns over 8 times. Great. Then say I drive the truck and get it hot. If I **** Tue truck off and say...go into a store or something, come out to leave and the truck has a lot of trouble starting. It will crank and crank like 20 turns then act like its dieing until I give a little gas to get er going.
Now if I,let's say "prime" it first. Turn key on and hear the fuel pump for about 10 seconds it will fire up like normal. 8 turns.
Now the problem is getting a little bit worse. I have to prime it twise to get it to go.
After the truck is started it runs and dives normal. Idles Fine. Runs out strong. Normal.
Any thoughts on this? There are no codes and I did the spark plugs when I did the fuel filter 2 years ago.
  #2 (permalink)
Old 03-22-2012, 06:15 PM
kbsupercrew's Avatar
kbsupercrew kbsupercrew is offline
Garage is empty, add now
kbsupercrew is starting off with a positive reputation.
I would get a fuel pressure tester and test your fuel pressure on the fuel rail, key on, then running, then key off for 5 mins for hold test
Since you dont smell gas at start up in the exhaust or smell of gas in the oil ,leading to a leaking injector or injectors
With the rail test you can see if your fuel regulator or the pump are working properly
  #3 (permalink)
Old 03-22-2012, 07:18 PM
FordGuy85's Avatar
1999 Ford F-250
Ok will do. Can you commonly rent a tester from a parts supplier typically?
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
