Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Other Ford Engines > Flathead V8 & Flathead 6
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 03-22-2012, 01:59 PM
55 f350's Avatar
55 f350 55 f350 is offline
1953 Ford F-100
55 f350 has a great reputation on FTE.55 f350 has a great reputation on FTE.55 f350 has a great reputation on FTE.55 f350 has a great reputation on FTE.55 f350 has a great reputation on FTE.
why do you need adjustable lifters with an aftermarket cam ?
it's been asked before , and i think i may have done so myself . but i am getting back around to my 53 and i was just curious . if i understand what i am reading , outside of easy valve adjustment , the only reason for them is if you run a reground cam as it reduces the lobe base circle , right ? i am considering 2 different cams besides my 8cm's , one the tilden 8cm plus if i ever hear it gets ground , and one from camcraft that has real good intensity numbers etc. i want to run the oe lifters if i do , but want to make sure they're cool with a new , not reground , cam from the aftermarket . so school me again guys as i have let it slip out of my thoughts ....................
__________________
that's because were all opinionated bullcrap artists looking for somewhere to espout our views and show the world how much we { don't } know especially to newcomers. were on a mission to impress you and make you believe we are all knowing ! P.A.D.D = project attention deficit disorder . everyone on here has it , and is an enabler !!!! so enter at your own risk !!!!!!!!!!! if you don't have 2 or 3 broken fords / projects , then you just ain't right !!!!!!!!!!!!!!!!
  #2 (permalink)
Old 05-07-2012, 05:19 PM
f5fordgirl f5fordgirl is offline
Garage is empty, add now
f5fordgirl is starting off with a positive reputation.
I would think that if you installed a reground cam, and used orig lifters your valve stems may be too short. On the other hand, if you installed a performance cam with higher lift, shortning the valve stems to get the correct clearance, may be getting too close to the keepers.
  #3 (permalink)
Old 08-12-2012, 11:13 PM
55 f350's Avatar
1953 Ford F-100
hmm thanx for the input . more too thnik of . i got a set of valves out of the early 4.6 that are measuring out nicely and have the right head diameter tha i'm wondering if they wont work with oe's and an aftermarket cam . problem is though i gotta find some one to put a bronze sleeve in the guides to make them right for the smaller stem size diameter so ..... i will find out why the run 'em , and i dont want to mill the valve stems down to any degree to make it work . i geuss i oughtta stop trying to reinvent the wheel ...............
__________________
Tags
350, 73, adjustable, aftermarket, block, cam, camcraft, camshaft, complaints, ford, high, lifters, lightning, market, mybb, performance, powered, valve
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
