Care to share your PI casting numbers? - Ford Truck Enthusiasts Forums
Modular V10 (6.8l) SPONSORED BY:
Old 03-22-2012, 01:03 PM
redrock82002 redrock82002 is offline
redrock82002 is starting off with a positive reputation.
The short verson of a long story go's like this. Doing the NON PI heads to PI heads conversion and the source for my heads fell thru. I will now be purchasing rebuilt heads from Odessa cylinder heads in florida, they come with a two year warrenty and will take my non PI heads as the cores. I need the casting numbers for any 2 valve PI head 01-2003 to get them coming. Can anybody throw me a bone or better yet share their casting numbers with me. anybody have a pic of their numbers? It would be greatly appreciated.
Old 03-22-2012, 04:54 PM
Ironhand03 Ironhand03 is offline
Ironhand03 has a superb reputationIronhand03 has a superb reputationIronhand03 has a superb reputationIronhand03 has a superb reputationIronhand03 has a superb reputationIronhand03 has a superb reputationIronhand03 has a superb reputationIronhand03 has a superb reputationIronhand03 has a superb reputationIronhand03 has a superb reputationIronhand03 has a superb reputation
Give me a few minutes.
Old 03-22-2012, 05:33 PM
Old 03-23-2012, 09:02 PM
thanks Ironhand03 that worked perfect
Old 03-23-2012, 11:40 PM
Not a problem.
Old 03-26-2012, 01:44 AM
I am getting differing versions from folks I know about how hard the head swap is going to be. I am being told that you have to remove everything on the front of the motor to include the front crank seal, Is this true? I was under the impresson that you can remove the camshaft gear from the cam and remove the head . Am I way off on this?
Anybody care to share their experiences with this
Old 03-26-2012, 05:12 AM
You pull the timing cover off(have to pull harmonic balancer too). Then remove the bolt that is holding the cam gear in place. After that slide the cam gear off of the cam and you are able to lift the head off, with the head bolts off of course.
Old 06-11-2013, 07:47 PM
C-Leigh Racing C-Leigh Racing is offline
C-Leigh Racing is starting off with a positive reputation.
Those numbers cast into the heads, where are they located on the heads & would they be hard to see on a motorhome chassis.
Thanks, Neil
PI Heads vs. Excursion heads 5.4 flyingtexan Modular V8 (4.6L, 5.4L) 3 12-21-2016 03:20 AM
PI vs Non PI heads onadraw Modular V8 (4.6L, 5.4L) 3 04-07-2015 12:14 AM
Help Identify Head BigBlue99 Modular V8 (4.6L, 5.4L) 3 07-22-2013 04:33 PM
5.4 PI and non-PI welder1 1999 to 2016 Super Duty 6 10-01-2009 06:20 PM
PI head swap BURNSTOUGHFORD 1997 - 2003 F150 64 02-21-2009 08:23 PM
Tags
54, casting, cylinder, ford, head, heads, id, identification, number, numbers, pi, v10
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
