ICP PRESSURE QUESTION
Check the IPR%. As long as it's in the 16-24% range at low idle then the truck is correctly building and maintaining HPO. IIRC mine runs 580ish hot and 620ish cold, it seems like it changes its mind sometimes but I only have this PID up randomly, and since people usually put up numbers around each of those I'd guess each one is acceptable to the PCM.
As I understand it, if you were having a small HPO leak the ICP would probably still be in the 580-620 range, but the IPR% would be jacked up over 65% because the valve is doing all it can to restrict drainage to counteract the leak. If you have a really bad leak, ICP won't go over 500 and the truck won't start.
Forgot 1 thing truck has also GOT to be in PARK for all tests
ECT 186 is fine for test or close enough
And then take again when your having your Hot Hard Start Issue
Take Both ICP psi and Also ICPV (VOLT) if you can and IPR% at everytest/hardstart Both numbers are good to have But we will mainly look at IPR%
This Test Procedure must be Done Exact or you will have skewed results
Typical diagnostic reference values straight from the PC-ED (2007 MY): note- reference values may vary up tp 20% depending on operating conditions, engine load, temperature, altitude, and other factors.
IPR%:
KOEO - 14.84
Hot Idle - 22
30 mph - 29.3
55mph - 36.33
ICP:
KOEO - 0
Hot Idle - 580
30mph - 858.6
55mph - 1126.6
I don't know where the low idle/high idle thing in all the SCII coding lists came from, I only have the Ford manuals to go off of.
IPR%:
KOEO - 14.84
Hot Idle - 22
30 mph - 29.3
55mph - 36.33
ICP:
KOEO - 0
Hot Idle - 580
30mph - 858.6
55mph - 1126.6
IPR%:
KOEO - 14.84
Hot Idle - 22
30 mph - 29.3
55mph - 36.33
ICP:
KOEO - 0
Hot Idle - 580
30mph - 858.6
55mph - 1126.6
IPR%:
KOEO - 14.84
Hot Idle - 22
30 mph - 29.3
55mph - 36.33
ICP:
KOEO - 0
Hot Idle - 580
30mph - 858.6
55mph - 1126.6
Those values came from Cheezit
So the Ford Manual Had ICP and IPR% Values for 30mph and 55mph?? that you Posted Here
I did notice that you posted these values may have a 20% Diffrence to me thats pretty BIG Diffrence.
IMO 5% IPR% the wrong way would mean Leak
The Reason I asked to take Numbers is all the Varibles are Controlled at ECT190* and at Low Idel and at High Idel (2500rpm)
Driving down the road has to many Varibles Wind drag or going up a Hill
Heres the Values I got from Cheezit below
In order at KOEO & Low Idel & hIGH iDEL (2500RPM) Last set of numbers would be sensor Range
ICP{ 0.2 KOEO}{1.0Low Idel}{1.8high Idel} {0.15 - 4.7range} VOLT Injection Control Pressure
ICP_DES 0 625.5 1400 - 1450 0 - 4045 PRESSURE (PSI) ICP Desired
IPR # 14.84 24 40.60 0 - 50 PERCENT Injection Pressure Regulator
All those Sensor Values Look Fine to Me
IMO you dont have a High Pressure Oil Issue
next time it has a Hot Hard start take those numbers again and comparethem to the Values
I think your starting issue is something else though
John7894
04-16-2021 06:58 AM
M.Farragher
10-15-2010 05:35 PM
