Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > New England Region > Connecticut Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Connecticut Chapter Join Chapter, Leader: StreamlineGT
  #1 (permalink)
Old 03-22-2012, 10:26 AM
mudman00x's Avatar
mudman00x mudman00x is offline
2000 Ford Excursion
mudman00x is gaining momentum as a positive member of FTE.
need a new transmission
toasted my trans in the excursion it puked out the front seal while towng a large dump trailer , anyway people of CT wheres the best transmission shop in CT?
  #2 (permalink)
Old 03-22-2012, 04:52 PM
trackspeeder's Avatar
trackspeeder trackspeeder is offline
Garage is empty, add now
trackspeeder is gaining momentum as a positive member of FTE.
The factory gray pump seal is known for leaking when over heated. Might just need a pump seal. There is an aftermarket viton seal that will prevent this from happening.
Jerry's in Guilford.
__________________
Speeder
01 F250 SD 4x4, XLT,7.3 Diesel.
90 F350 4X4 XLT, CumminGs Diesel, Aint stock E4OD
85 F250 4x2 Xl, 6.9 Diesel, waitng for help
Easy Photo Button
  #3 (permalink)
Old 03-22-2012, 04:53 PM
acf6's Avatar
acf6 acf6 is online now
2003 Ford F-250
acf6 has a brilliant futureacf6 has a brilliant futureacf6 has a brilliant futureacf6 has a brilliant futureacf6 has a brilliant futureacf6 has a brilliant futureacf6 has a brilliant futureacf6 has a brilliant futureacf6 has a brilliant futureacf6 has a brilliant futureacf6 has a brilliant future
miles.degrandi
Ray (rocdril) had the transmission in one of his race trucks rebuilt by a place on the silas deane highway i think... maybe Aaron or Ray will chime in
__________________
Miles
2003 F350 KR 4x4 - 6.0L
-ARPs, egr delete, coolant filter, blue spring, 4" MBRP, SRL+, SGII, 4" lift/35s, empty wallet, etc
  #4 (permalink)
Old 03-22-2012, 05:06 PM
gbroehl1's Avatar
gbroehl1 gbroehl1 is online now
gbroehl1 is a name known to allgbroehl1 is a name known to allgbroehl1 is a name known to allgbroehl1 is a name known to allgbroehl1 is a name known to allgbroehl1 is a name known to all
A friend of mine used Denny's here in Bristol and was very happy with the work and the customer service.
__________________
Greg (aka Montana Heavenjugs)
2001 F250 XLT PSD CC SB - Tuned by Gearhead
6637 w/ Pete's cover; DashDaq; RR HPX, FRx; 5" MBRP SS turbo back; 6.0 IC and trans cooler; Retrax bed cover
NorthEastSevenThrees <-- link to our homepage
  #5 (permalink)
Old 03-22-2012, 06:22 PM
mudman00x's Avatar
2000 Ford Excursion
i know its toast slipping and shuddering when you get on it its ok if you drive real easy but as soon as you get on it its a no go so thanks ill check em out
Tags
ford, transmission, transmissions, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
