Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1957 - 1960 F100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 03-22-2012, 08:23 AM
mkrog mkrog is offline
Garage is empty, add now
mkrog is starting off with a positive reputation.
HELP,C.V. ifs install bolt holes
Need some help from anybody that's installed a C.V. IFS.How did you get the holes need in the frame to line up top to bottom.This on a 57 F 100.
  #2 (permalink)
Old 03-22-2012, 12:51 PM
fast58's Avatar
fast58 fast58 is offline
fast58 is starting off with a positive reputation.
Kyle Brazier
I jacked the front suspension up until the "pegs" touched the frame. Then I aligned the whole suspension left and right along with spacing from the front. After I got the front suspension sitting the way I wanted it, I marked the holes on the bottom of the frame (through the factory holes in the CV IFS) with a paint pen. Then I bolted the top part of the front suspension on (the part that kind of folds over on top of the frame ). Then I marked those holes as well with a paint pen. After I got all the holes marked I drilled them out.
NOTE: Once I got the holes drilled out, the sleeves fit very tight and had no "wiggle room" to fine tune the adjustment; so I cut the holes out a little larger in diameter with a torch to accommodate. I also used the 12"-15" section of frame off of the CV that the suspension bolted through. You can check my Buildup thread to get more details.
Hope this helps!
__________________
http://www.ford-trucks.com/forums/im...ine=1324186537
1958 Ford F-100. 351 W .030 over and Speed Pro flat top pistons, Comp Cams 224/226, World Windsor Sr. heads, Edelbrock Performer intake, Holley 750 carb, Roller rocker arms, Proform one-wire distributor, MSD 6-AL ignition.
Tags
ford, ifs, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
