Changing from a '58 to a '57
Okay, I was in the junkyard getting a hood for my '58 F-100. I found the "ribbed" beauty on what I think is a '57 F-600. The reason I think it is a '57 is because it had the single bar, single headlight grille with the big ol' V8 emblem in the center. I have a great desire to have this grille on my '58 and I have plans to go back to get it this weekend.
My question is: If I change the grille to a '57 ,and the hood of a '58 and '57 are the same, Does changing the grille out essentially visually change my truck from a '58 to a '57?
After looking at several pictures of '57 trucks, the only difference I notice between them and a '58 is the grille. Am I wrong?
Thanks in advance for the expertise/input/B.S.
I believe the elec. plugs on a 58 and up on the firewall is a dual outlet. (for the lights ect.) Not for sure but I believe the 57 is a single plug. I will check at Riff's place when I go in the morning. If you get a chance and the headlight doors (the outer stainless steel ring) are still there grab them. They are the hardest to come by.
Jonesy
Jonesy
Jonesy
Jonesy
Yes the front end will change over. The hood, which I think is a better looking hood, & the grill will change over. 7 & 8 hoods are the same except the emblems that go on the side of the hood are different. If you need another ring there is one available. P.M. me for more info. And also the bumper is different for 7 ? not sure I will look at yours and let you know.
Dude, My thoughts have not been clear last few days. I had a semi hit me on I-40 in my Explorer. Totaled it out. Had to drive back to get my truck so I can head to Roswell Nm. for work.
The 57 and 58 are the same frames. 1959 is where the front frame horns step up where the bumper sits. Sorry my bad.
Jonesy
Jonesy
I'm glad you are still alive! That sounds pretty rough.
Funny thing.. I just got done watching an episode of "UFO Files" on the History Channel, and they were talking about a UFO crash in Roswell, NM in the 50's. They went on to talk about how the government supposedly stored all the crash debris and "bodies" in Hangar 18 at Wright-Patterson AFB in Ohio.
I just found some ironic humor in that because you said you work in Roswell, NM. I'm sure you've heard plenty about that though.
Thanks for the input!
quaintance
16
01-27-2009 02:38 PM
samahi72
04-20-2004 02:32 PM
