Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1957 - 1960 F100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1957 - 1960 F100 & Larger F-Series Trucks Discuss the Box Style Ford Trucks SPONSORED BY:
  #1 (permalink)
Old 03-22-2012, 06:57 AM
fireball14513 fireball14513 is offline
1960 Ford F-100
fireball14513 is starting off with a positive reputation.
Fuel Pump Alternative?
Just bought an AIRTEX fuel pump for my 60 ford 292 Y-Block...it pumps like crap...decided to take it off to see something was wrong with it and found aluminum shavings inside one the ports,took the canister off and fuel filter inside doesnt want to stay on, the canister gasket is so swelled that you cant even put the canister back on.. Is there another mechanical pump that I can use that is better quilty....Right know Im headed towards a Carter elec. ....I will never by AIRTEX pumps again
Thanks Mark
  #2 (permalink)
Old 03-22-2012, 01:48 PM
F250racer's Avatar
F250racer F250racer is offline
Garage is empty, add now
F250racer is starting off with a positive reputation.
I'm using one of those Carter inline electric fuel pumps, works great. You can get a block off plate for your mechanical one from NAPA or O'Reily's in the Mexican isle, they're like $8.
__________________
Colin
'59 F-250 Styleside Longbed, 292, 4spd, Rockwell 5.83 dually running gear, custom NP205 overdrive.
"The truck's a Ford and the tractor's green"
  #3 (permalink)
Old 03-26-2012, 11:48 AM
Byrd.Dog's Avatar
Byrd.Dog Byrd.Dog is offline
Byrd.Dog is starting off with a positive reputation.
I think any pump for an FE block will work. I just swapped out mine. The replacement I got was for an 80-83 302.
  #4 (permalink)
Old 03-26-2012, 11:49 AM
Byrd.Dog's Avatar
Quote:
Where are you pulling power from? Also, did you have to wire in a relay, or just connect straight to a keyed power source?
  #5 (permalink)
Old 03-26-2012, 07:46 PM
F250racer's Avatar
I have an aftermarket wiring harness that already had a fuel pump line. If you're doing it from scratch then I'd probably use a relay triggered off a keyed power wire.
__________________
Colin
  #6 (permalink)
Old 03-27-2012, 01:16 PM
2losteve 2losteve is offline
2losteve is starting off with a positive reputation.
2losteve 2losteve 2losteve
Airtex
Quote:
Thanks Mark
And I thought they were one of the best!
__________________
'56 F-100
'57 F-100
'54 Chev sedan del
'71 C-10
Tags
airtex, fuel, pump, working, yblock
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
