Why are there good 6.0 engines and then bad
Besides the obvious how the vehicle is driven and maintained. why do so many people have problems with the 6.0 but then there are others like myself who have had next to none? Is there a vehicle year when more people have had problems with the 6.0 than other years? I catch a lot of negative comments about driving a 6.0L but in my experience it's been an amazing truck. Just curious if some of you guys who know tons about 6.0's will chime in and school me.
I work at Ford Oakville Plant in Ontario Canada. There is no such vehicle as a "Friday or Monday" vehicles. Not to say that we don't work on Monday or Friday. At some point a component is assebled on any one of those days, but not a complete unit or even majority of the assembly of a complete unit could be called a "Friday or a Monday". Even if a vehicle could have a majority of it's assembly done on either of these days. What would be the chances of those people meeting up and talking about there "Friday/Monday" vehicles.
The assembly work done on vehicles has no bearing on the day of the week. All tools to assemble these units are electric smart tools, tied to an electronic monitor that keeps work done with these tools constant and deliberat. Any deviation is recorded and followed with the unit until it reaches it's repair station and a quality control display that has identified this unit as having an issue. It's repaired then and there. If not the issue will follow the unit until it tries to leave the plant. At that point, all unit must be scanned for any outstanding issues and will not leave the plant until all system pass this unit.
So there, no more " Friday/Monday" units.
I hope I got that right.
I remember touring the local Catepillar plant in high school and that was cool.
To actually answer the OP's question..
I honestly think that most 6.0 owners are fairly happy with their trucks. There are hundreds of thousands, maybe millions of them on the road.
I see them driving on the road everyday. If they were "real world" that terrible they would all be in the scrap heap.
Honestly, the 6.0 wasn't ready for our high sulfur fuel and it jacked them up.
Lots of folks had coolant leaks with the EGR Cooler and thought they had head gasket failure, so they did $5000.00 in repairs to a perfectly good motor.
Another thing was the dirty High Sulfur Diesel that was available in 03. It played havoc on the injectors, and the Turbo and the emissions control systems. Plus people adding a bulldog and other type of tuners to make more power, it was just a perfect storm to wreck IH and Ford Trucks reputation with Diesel Motors.
Nevermind the crappy Radiator cap that Ford Put on the PSD, holding no pressure on the system and the coolant literally boiling under load, yup, more blown head gaskets.
never mind owners not getting the best available filters, or sticking to the maintenance schedule like the should.
I am not saying there are no issues with the 6.0, however there are several out there which have 200+k reliable miles on them.
Ironic that the avalanche of negativity was concentrated on this motor 6-7 years or so ago. I think that a lot of the fuel supply related failures has gone away with the arrival of the ULS Diesel fuel.
Ok, I'll probably get blasted for this, but I would buy a well maintained 6.0 in a heartbeat and then I will treat her right.
Thanks!
Thanks!
I bought my 05 King Ranch new. I have changed the oil every 5K religiously, serviced the tranny as required, changed the coolant, kept that K&N filter clean, fuel separator drained at every oil change, keep fuel filters changed, changed the pads, replaced the shocks, and replaced tires. The only major issues was the replacement of 3 injectors around 140K. It is all just upkeep and so far the truck has not let me down. I hear about oil coolers, head bolts, etc. and so far at 151K I just do not have those type of issues. I can only summarize and say that it is a mechanical machine and upkeep will keep it running; but you are still going to get failures.
When someone asks me if I have had problems with my truck,I usualy tell them about stripping out my hfcm drain,defective tire and cam position sensor,then ask if they have had and trouble with thiers. Often they have had more problems with thier Cummins or Duramax than I have with my Power Stroke.
