1965 Cruise o matic rear seal/Trans code - Ford Truck Enthusiasts Forums
Old 03-22-2012, 06:22 AM
jim7044 jim7044 is offline
jim7044 is starting off with a positive reputation.
I have a 1965 F250 camper special, 352 automatic all original. Trans code on door plate is "G". Is it a cruise o matic? Axle code is 24, is this 4:10?
Also it leaking trans fluid where the speed o meter cable goes in. Is there an o ring in there that can be changed? Also leaking a little at the rear seal where the drive shaft goes. Do I need to remove the short tail stock to change the rear seal or just the yoke and big nut and pry it out? I called the local parts store and got a price of anywhere between $2 to $30 for the rear seal. Does any one know the correct part # for the rear seal?
I'm 90 % sure I have two leaks after cleaning the area many times over about a week and driving the truck daily. Thanks for any help.
Old 03-22-2012, 11:17 PM
SuperSabre's Avatar
SuperSabre SuperSabre is offline
SuperSabre is gaining momentum as a positive member of FTE.SuperSabre is gaining momentum as a positive member of FTE.
You are correct that transmission code G is a Cruise-O-Matic for your application and transmission code 24 is a 4.10 ratio in a non limited slip Ford 9 inch rear end. I looked in my '64 - '72 Ford Truck Master Parts and Accessories manual and found the following part number (good as of 1975!) for your transmission's "Seal, Transmission Output Shaft, Oil":
B3TZ-7A011 - A. I did not see an O-ring in the picture, but my (frequently faulty) memory tells me there is one at the end of the speedometer cable where the gear is attached, where it enters the transmission housing. If you can get hold of the aforementioned manual, there is an illustration of what you are talking about in Section A70, page 2. Hope this helps.
Old 03-23-2012, 01:30 AM
Boss9F100's Avatar
Boss9F100 Boss9F100 is offline
Boss9F100 has a very good reputation on FTE.Boss9F100 has a very good reputation on FTE.Boss9F100 has a very good reputation on FTE.
Nope, not a 9" but a Dana 60.
Old 03-23-2012, 11:46 AM
SuperSabre's Avatar
Ooops! Of course it is! My reference said the same thing if I'd only bothered to read it properly. I'll start remedial reading lessons tomorrow. Thanks for the catch, Boss!
Old 03-30-2012, 08:36 AM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
You are correct that transmission code G is a Cruise-O-Matic for your application.
FoMoCo used the G Warranty Plate TRANS code for EVERY F100/350 Automatic Transmission thru 1978.
One had to know which trans came with what engine.
G examples = 1965/67 F100/350 352 = MX Cruise-O-Matic / 1965/72 F350 300 I-6 = MX Cruise-O-Matic // 1965/67 F100/250 240/300 I-6 & F350 240 I-6 = C4 Cruise-O-Matic.
TCAA-4676-A (replaced B3TZ-7A011-A) .. MX Output Shaft Seal / Timken part number: A-1205-G-683 or A-3366-V-126 / Obsolete
87036-S94 .. Speedometer Cable O-Ring / Available from Ford.
Some Passenger Car/F100/350/Bronco/Econoline applications: 1951/70 2 and 3 speed Ford-O-Matic / 1958/67 FX & 1958/72 MX Cruise-O-Matic / 1964/81 C4 / 1966/97 C6 / 1969/85 FMX / 1980/92 AOD and etc.
1965 cruise-o-matic dipstick part no yargnitram 1961 - 1966 F-100 & Larger F-Series Trucks 3 05-31-2014 12:22 AM
Cruise o matic Kizer12 1961 - 1966 F-100 & Larger F-Series Trucks 4 04-21-2014 06:14 PM
3 Speed Manual Transmission Problem. Bigfoot21075 1961 - 1966 F-100 & Larger F-Series Trucks 5 03-16-2010 07:12 AM
Cruise-O-Matic replace seals or not? 66_in_ky Clutch, Transmission, Differential, Axle & Transfer Case 3 06-21-2009 04:18 PM
Help! Delayed intial engagement Cruise-O-Matic tranny? zeus77 1961 - 1966 F-100 & Larger F-Series Trucks 18 03-20-2007 01:39 PM
Tags
1963, code, codes, cruise, drive, ford, matic, maticford, numbers, part, rear, seal, straight, transmission, truck, trucktranmidssion, yblock
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
