Turbo 292 yblock - Ford Truck Enthusiasts Forums
Turbo 292 yblock
Old 03-21-2012, 09:37 PM
F250racer's Avatar
F250racer F250racer is offline
F250racer is starting off with a positive reputation.
Turbo 292 yblock
I've been throwing around the idea of putting twin turbos on my 292 yblock. My truck is a truck not a race car, the main goal is I think it would be a cool project and a little extra power never hurt anything, but it will probably never really be fully wound out and hot rodded around.
I feel like the motor could probably handle around 7psi or so of boost. Just wondering if anyone had any ideas on what turbo to use, looking for probably a 4cyl car that came stock with a turbo that I could find easily at a junk yard.
Only problem is I really don't know how to figure out how much flow I need or how to know which pair would work well? Any input on all of this?
Old 03-21-2012, 10:07 PM
theodore/teddy's Avatar
theodore/teddy theodore/teddy is offline
Refyred
theodore/teddy is a splendid one to beholdtheodore/teddy is a splendid one to beholdtheodore/teddy is a splendid one to beholdtheodore/teddy is a splendid one to beholdtheodore/teddy is a splendid one to beholdtheodore/teddy is a splendid one to beholdtheodore/teddy is a splendid one to beholdtheodore/teddy is a splendid one to behold
Colin; Check-out Hot Rod magazine's May 2012. They have an article the will help you wrap your head around all the info you need to set up your first turbo.
I for one would like to see you do this project. From a working truck stand point you would be able to run up and down the cascades without braking stride.
Good luck in your quest!
Old 03-22-2012, 04:38 PM
mcdonaldm mcdonaldm is offline
mcdonaldm is gaining momentum as a positive member of FTE.
i would look for the turbos off a Turbo T-Bird, specifically the 87 version with the intercooler. i see a few of them in the local pick a part yard from time to to time (or a SVO Mustang same thing but harder to find) and think they should work out pretty good.
a 292 is roughly 4.8L and the turbo t-bird was a 2.3l so two of them should feed your 292 pretty easily seeing as the 292 heads are not overly efficient port designs.
but there is lots of info on the net about turbos and proper selection and sizing, so do some research on the subject.
sounds like an interesting project. keep us informed.
Rgds
Mike
Old 03-23-2012, 03:53 PM
F250racer's Avatar
someone else was actually telling me to look for those also. Seems like they're work pretty well, was reading online and looks like they made about 9-15psi of boost depending on auto or manual trans. That could always be brought down with wastegates depending on what it ends up actually putting out on the truck.
I'll poke around in the junk yards, just worried it might be hard to find two of these without going broke. I feel like I don't see many of those cars around let alone at the pull-a-parts.
Old 03-24-2012, 07:27 AM
Walston's Avatar
Walston Walston is offline
Walston has a great reputation on FTE.Walston has a great reputation on FTE.Walston has a great reputation on FTE.Walston has a great reputation on FTE.Walston has a great reputation on FTE.
The Mercury Cougar in 1986 and 1987 also had this setup. I had an 86. According to the PSI gauge on the dash, it would routinely get in the ballpark of 15 psi.
Origins for my Y-Block?? Any ideas? brit_wheels_fan Y-Block V8 (239, 272, 292, 312, 317, 341, 368) 15 01-06-2017 12:41 AM
Yblock crank bolt size? 562f100 1961 - 1966 F-100 & Larger F-Series Trucks 2 08-14-2014 09:26 PM
horsepower from a y-block handx2 Y-Block V8 (239, 272, 292, 312, 317, 341, 368) 60 08-22-2013 06:05 AM
how much compression out of a 292 59flatbedford Y-Block V8 (239, 272, 292, 312, 317, 341, 368) 8 03-20-2007 05:33 PM
Y-Block Fuel Efficiency. Greg Bockelman 1948 - 1956 F1, F100 & Larger F-Series Trucks 7 11-15-2005 04:28 PM
Tags
292, block, ford, junkyard, power, turbo, turbocharged, twin, yblock
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
