Go Back   Ford Truck Enthusiasts Forums > Older, Classic & Antique Trucks > 1957 - 1960 F100 & Larger F-Series Trucks
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
1957 - 1960 F100 & Larger F-Series Trucks Discuss the Box Style Ford Trucks SPONSORED BY:
  #1 (permalink)
Old 03-21-2012, 08:30 PM
lwclark's Avatar
lwclark lwclark is offline
1960 Ford F-100
lwclark is starting off with a positive reputation.
Oil drain plug
Hi guys. My oil drain plug won't tighten. It just spins and spins. It had a bunch of plumber's tape on it, obviously a P.O. knew about it. A new oil pan is the only solution that I can think of. Is there a common and cheaper fix?
__________________
Larry
1960 F100 Custom Cab Styleside
1966 MGB
I have no idea what I'm doing. May as well get started.
  #2 (permalink)
Old 03-21-2012, 08:42 PM
thundersnow70's Avatar
thundersnow70 thundersnow70 is offline
1960 Ford F-250
My Garage
thundersnow70 is starting off with a positive reputation.
they make kits that fix stripped oil pan threads. you retap the hole and then you install an oversized plug. or you could be really hillbilly and weld a nut on the bottom of the pan over the hole and plug it with a bolt and soft washer. no offense to any hillbillys of course.
__________________
52 F2 & F3 Merryman Herringbone
60 F250 4x4
63 F250 4x4 Flareside
Mark
I might be in a cage at the zoo, but I'm still king of the jungle!
  #3 (permalink)
Old 03-21-2012, 09:14 PM
ibuzzard's Avatar
ibuzzard ibuzzard is offline
In Memoriam.....
Garage is empty, add now
ibuzzard has a very good reputation on FTE.ibuzzard has a very good reputation on FTE.ibuzzard has a very good reputation on FTE.ibuzzard has a very good reputation on FTE.
Quote:
Hillbillies are people too - aren't they?
__________________
"Why, yes, I have plenty of spare change, you worthless piece of crap."
'59 F250 w/an Engine, a Transmission, Some Tires/Wheels, PLUS-a Genuine Radio
" Entitled, self-absorbed kids - meh."
  #4 (permalink)
Old 03-21-2012, 09:27 PM
F250racer's Avatar
F250racer F250racer is online now
F250racer is starting off with a positive reputation.
drill/tap or get one of those expandable rubber plugs
__________________
Colin
'59 F-250 Styleside Longbed, 292, 4spd, Rockwell 5.83 dually running gear, custom NP205 overdrive.
"The truck's a Ford and the tractor's green"
  #5 (permalink)
Old 03-22-2012, 12:13 AM
GB SISSON's Avatar
GB SISSON GB SISSON is offline
GB SISSON is gaining momentum as a positive member of FTE.GB SISSON is gaining momentum as a positive member of FTE.
Happened to me first time I changed the oil in my 223. Town is a 24 mile round trip so I put a 3/4" length of fuel line over a round head bolt, maybe 5/16 or whatever fit, stuck it in the hole, held the threaded end with vice grips and expanded the rubber plug. There was a washer both sides of the rubber. The free version of the one f250racer suggested. Never leaked a drop.You could double nut it or use a nyloc nut if it made you feel safer......
__________________
'92 F350 4x4 dual wheel service truck. 7.3 with headers and glass packs. 5 sp man tran. 255 85 16 Toyos. 110,000 miles. '59 F350 9' flareside new project, cummins 6at turbo diesel, sm 465 4 spd. 255 85 16s again, 37 ford 1 1/2 ton stake with 53 flathead V8. 65 toyota landcruiser fj 45 longbed pickup. 54 GMC 3/4 ton flatbed w/ cummins 6at, '68 BSA 441 Victor Special, bone stock, Antique tractors and one lung flywheel engines .....
  #6 (permalink)
Old 03-24-2012, 05:54 PM
1960 Ford F-250
My Garage
yea Buzz, hillbillys are people to. my wife says i am one. GB...great pic! i'm gonna have to remember that one.
__________________
60 F250 4x4
Mark
  #7 (permalink)
Old 04-03-2012, 07:06 AM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Guru
2013 Ford Escape
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
There are two different sized oversized drain plugs sold by parts stores. These plugs cut their own threads, so there is no need to drill and tap.
__________________
Bill // Retired Ford Parts Manager // SoCal Chapter member // Part Number Research: 1928/2001 FoMoCo vehicles.
2013 Escape SE FWD 2.0L Eco-Boost.
Tags
37, 460, drain, engine oil, f100, f150, f250, ford, location, number, oil, oil pan, part, plug, tighten
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
