purpose of fuel switch on dashboard
Old 03-21-2012, 07:15 PM
jdad49's Avatar
jdad49
jdad49 is offline
I recently bought a 1976 F-150 Ranger. It's a good truck but, I have a question about it. There is a switch by the heater controls that says fuel/auxillary. What is the purpose of this switch? Does the truck have an auxillary fuel tank?
Thanks for your time. I'm sure more questions will pop up from time to time.
Old 03-21-2012, 07:23 PM
fmc400's Avatar
fmc400
fmc400 is offline
MSEE
It should do two things: (1) switch the tank solenoid to pump from either tank, and (2) make the fuel gauge read from the tank you're using. How many fillers on the driver side of the bed? Should be a pretty quick check to see if you actually have one or two tanks.
Old 03-21-2012, 11:05 PM
Ohiocrewcab's Avatar
Ohiocrewcab
Ohiocrewcab is offline
It might have the in cab tank as well 76 should be the last year for that option. And then one all the way in the back.
Old 03-22-2012, 08:12 AM
jdad49's Avatar
jdad49
jdad49 is offline
There is only one filler neck on the side. But, I can only get a fuel gauge reading if it's on auxillary. If the switch is on main it reads empty. Is it possible the sending unit is bad, or maybe something else?
jdad49
Old 03-22-2012, 08:21 AM
82GT's Avatar
82GT
82GT is offline
Does your truck have a fuel tank in the cab, behind the seat? If not sounds like someone removed the main and only runs with the auxillary, no tank, no sending unit
Old 03-22-2012, 09:49 AM
Pickupmanx2's Avatar
Pickupmanx2
Pickupmanx2 is offline
My 77 has the in-cab tank,, it is the main,, my 73 SCS has two in the bed, and the rear one is the,,, one of them!! I forget,, shoot,, and my 76,, and 79,, well the 79 front tank is out,,heck I am gonna have to look again see which is which,,, but yes your in cab should be the main,, and if it is gone,, it no worky!
Old 03-22-2012, 12:09 PM
bamaf150's Avatar
bamaf150
bamaf150 is offline
My '76 has 2 tanks, the main is in cab behind seat and the aux is behind the rear axle. Pickupman, I thought '76 was the last year for in cab tanks, what gives with your '77?
Old 03-23-2012, 10:21 AM
Pickupmanx2
I thought 77 was the last year,,, well at least on my side of the hill it was!!
Old 03-23-2012, 12:03 PM
mikeo0o0o0's Avatar
mikeo0o0o0
mikeo0o0o0 is offline
It was a mid year change for '77. This was due to government safety regulations banning in-cab tanks.
On trucks with both tanks under the bed, the main tank is the rear, aft axle tank. The auxilliary is the forward tank.
retsyr
20
01-22-2017 07:22 PM
Serg
02-20-2014 09:17 PM
predaina
29
03-29-2011 07:07 PM
StangMang
01-11-2005 04:44 PM
Quick Reply: purpose of fuel switch on dashboard
